Rear window defrost not working - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 03-23-2013, 08:06 PM
RoxyBMW RoxyBMW is offline
Bimmer Lady
Mein Auto: 525i
Hello, i have tried getting my rear window defrosted early in the morning but its not working. I press the button to turn it on but the light next to the button doesnt come on nor does it defrost window
Old 03-23-2013, 08:42 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Check fuse #28. It may be blown. If so, replace it.
There is also a rear defogger relay in the rear power distribution box located under the rear seat cushion. You don't tell us what year your car is. This is important because the relay location in the 89 and 90 models are a little different than the 91 and later models.
If you have the Bentley manual, take a look at page 610-2 for details.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-24-2013, 10:24 AM
Bimmer Lady
Mein Auto: 525i
My car is a 1995 525i.
Old 03-24-2013, 10:26 AM
Bimmer Lady
Mein Auto: 525i
Thank you so much. I will take a look at that page. Im very ignorant on finding my way around this book. Roxy
Old 03-24-2013, 10:31 AM
Alnlesley Alnlesley is offline
Mein Auto: 91'bmw ac schnitzer
Its probably fuse under the back seat. You might have to remove a few screws to take the plastic cover off covering the fuse panel. I had the same issue an it was the fuse on my 91 e34.
Old 03-24-2013, 11:00 AM
BMR_LVR's Avatar
Humble E34 lover
Page 610-2 shows where the relay location is, but not the fuse location. The fuse location is on page 610-1. The fuse is located in the front power distribution box which is on the driver's side behind the strut tower.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-24-2013, 11:44 AM
manuelwindows manuelwindows is offline
Mein Auto: 1994 530i, 1977 320i
is this also happening in conjunction with the AC not working? check to make sure. if the AC is also not working as well or that light there by the AC or the Recirc button are blinking or lighting up orange instead of green, then most likely not the fuses and instead it is the IHKR, which is your climate control module and which is the "brain" that controls the rear defrost, AC and recirc buttons and it can get a little corroded and sometimes just needs to be cleaned.
I had this problem a little while ago. It was the IHKR.
(I have a '94 530i which might have a different climate control module than your car. You might have the "sword" as a climate control module which looks more like this one on eBay here that came from a '94:
http://www.ebay.com/itm/E34-525i-530...item2579ed66eb
There seems to be significant variation within models on this. whether it is called an "IHKR" or "climate control module", or the "sword" can be different between years and the ease of pulling it out from behind the controls in the dash can also vary widely I learned when I had this problem. But it turned out I didn't need a new one but that I just needed to clean the corrosion on my existing one with a toothbrush. Bentley's will tell you which you have and how to remove it. I found some replacements for about $75 for the particular IHKR my car has but I didn't need to purchase one.
Could also be the #28 fuse in the front box or the relay by the fusebox under the back seat, as previously mentioned but that would just be too easy
