E34 (1989 - 1995)
Old 03-24-2013, 01:00 PM
Bugsie Bugsie is offline
Mein Auto: BMW E34 M50 2.5
How many bolts holding cylinder head
Hi all.
I'm on the process of changing the head gaskt and until I've removed 14+2 torx bolts from the head and it stills looks stuck.
Mine is a M50B25 (06/1990 euro spec) and I found two more, not torx.
Aside from the 16 torx bolts, are there more to remove??
Best regards
Cheers
Fernando
Old 03-24-2013, 01:27 PM
south26 south26 is offline
Mein Auto: 535i 1989
Did you remove 2 small ones near the chains? One is on the other side form the thermostat and the other one is on the other side.
Andy
Old 03-24-2013, 04:55 PM
Hi all.
Yes Andy, I removed the two small E8 near the chains.
The other two that I mention are located between the cams, almost in the center.
Thanks for the input Andy.
Cheers
Fernando
Old 04-03-2013, 03:09 PM
Hi all.
I found the missing bolt.
There are 14 torx bolts (E12) and 3 more (E8): two located near the front timing cover and one is holding the timing chain guide. There are 3 holding the guide and; 2 on the front and the one that's also holding the head is the one in the back.
Cheers
Fernando
