Old 03-24-2013, 10:19 PM
HmHRemd HmHRemd is offline
Mein Auto: E36 M3
upper radiator hose
I have a 97 528i, and I have been bleeding the coolant system for days now. This morning when i opened the hood the upper radiator house was clapsed. Is this from air in the system?
Old 03-25-2013, 04:46 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
Bleeding for days....?I thought only women do this....
Well you are doing it wrong.I bleed mine in 10 mins.fill up till full.then open the thermostat bleed screw and blow at the filler neck till water comes out and not air or air/water mix and close the bleeder screw.
And what is clapsed?
Sent from my GT-I9070 using Bimmer App
Old 03-25-2013, 05:36 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Do yourself a favor, disconnect the top hose at the radiator and pour coolant into the hose until full, then quickly reconnect it.
I just replaced the coolant in my 540 yesterday. I filled the system thru the expansion tank right to 1" of the top of the tank. It took about 10.5 quarts.
Then with the cap still off I disconnected the top hose and poured another quart in the hose, when the hose is full and the level in the tank rises to overflow the tank I then reconnect the top hose and put the cap back on.
Start the engine with the heat at 90 and fan speed at low. Let it idle and look for leaks, then I took it for a 2 mile ride. Parked it in the garage and then checked the expansion tank about 3 hours later, I added about 8 more ounces. This morning the level was fine.
I never have to use the bleed screw.
2000 540/6 Slightly tweeked...everywhere
Old 03-25-2013, 05:39 AM
Originally Posted by moots View Post
blow at the filler neck.
moots, your getting way to intimate with with your car, LOL.
Old 03-25-2013, 06:16 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
If hose is collapsed, replace your radiator cap....the vacuum relief valve is not working.
Originally Posted by HmHRemd View Post
...........This morning when i opened the hood the upper radiator house was clapsed. Is this from air in the system?
Old 03-25-2013, 06:53 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
+1
Old 03-25-2013, 06:54 AM
rdl rdl is offline
Mein Auto: 530i 2003
EDIT: Oops - didn't mean to be repetitious. Just a combination of getting interrupted and slow typing
I assume "clapsed" = collapsed. This sounds like a problem with the radiator/expansion tank cap.
Rad caps usually have a one way check valve to allow air into the system if pressure falls below atmospheric. I assume the BMW cap does too.
Keep in mind that there is always air plus water & EG vapor in the top of the expansion tank. When the system cools overnight from the temperature during the bleeding process the vapour contracts which reduces pressure, perhaps below atmospheric at which point the cap's check valve opens to allow air to enter and equalize pressure. If the check valve doesn't operate properly, the rad hose collapses. The effect would be magnified if the bleed isn't complete and there is another air pocket in the head or cabin heater circuit.
I think this effect is the reason that many people report having to add a bit of coolant the next morning after bleeding the system. Once that 2nd small fill is done the system is stabilized to ambient temperature and no further addition is needed (at least we sincerely hope )
Regards
RDL
Old 03-25-2013, 05:29 PM
Mein Auto: E36 M3
Will try all of the above. Thank you all
