E36 (1991 - 1999)
Old 02-13-2013, 03:21 PM
redE36girl redE36girl is offline
Mein Auto: 1993 E36
this is a great one the cooling system stuff going wrong is why the previous owner just gave me the car for free.
1993 BMW 325i
1990 VW passat wagon
1987 jeep(AMC) cherokee
1979 VW westy rabbit 4 door
Old 03-20-2013, 11:02 AM
Blanche Blanche is offline
Mein Auto: 1992 325i
Originally Posted by Bmwcat View Post
Heh!! I am ordering a new radiator today, the plastic neck just snapped and its beyond repair..I have 109K on my car!!
Me too. 95K on my '92 325i. It's going to be my first non-oil change work done by myself. *crossing fingers*
Old 03-20-2013, 11:25 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
You can do it man! I never worked on a car untill I got my BMW 4 years ago. Just make sure you bleed and bleed and bleed the air out and you will be fine!
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 03-20-2013, 11:33 AM
Mein Auto: 1993 E36
rad swaps are easy the first thing I did was the cooling kit from bimmer world http://store.bimmerworld.com/e36-3-s...kit-p1167.aspx
1993 BMW 325i
Old 03-20-2013, 11:59 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Originally Posted by B1MM3R View Post
You can do it ma'am! I never worked on a car untill I got my BMW 4 years ago. Just make sure you bleed and bleed and bleed the air out and you will be fine!
Ftfy Jesse.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 03-20-2013, 12:10 PM
I'm looking at the same kit and am about to pull the trigger but I am hesitant...hoping that I can do it myself. It's just a machine, right?
Old 03-20-2013, 12:14 PM
Mein Auto: 1993 E36
its easy my hubby and i have never worked on a Bimmer before we got mine. an this was the first thing we did. very easy dont be afraid.
1993 BMW 325i
Old 03-20-2013, 12:15 PM
It's the ultimate driving machine, ahem. You can do it. If you get stuck just take lots of pictures of what you can't figure out and we'll help you get it done. I knew barely more than you when I started with mine. No worries, you got this.
Old 03-21-2013, 06:34 PM
bmwtogo bmwtogo is offline
Mein Auto: 2007 BMW 328i Sedan
Does the kit come with instructions or anything? If you plan to do more repairs yourself, some auto stores sell books to help guide people on repairs too. Just go for it
Old 03-21-2013, 06:42 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
There are highly detailed guides (DIY's) out there for nearly any job to do with an E36.
http://www.bimmerdiy.com is a great resource.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-24-2013, 09:24 AM
wilkins325is wilkins325is is offline
Mein Auto: 93 BMW 325is E36 2dr 5spd
ABS light??
I just bought a 93 325is which has a rear drivers side shock issue. I have yet to take it apart and check the issue. I am not getting the Popping sound or anything so im pretty sure its just a busted shock. Anyways, there is also an ABS light on the dash. The car stops great. Could this shock issue cause the ABS light come on?
Old 03-24-2013, 10:42 AM
jonesin's Avatar
The Canadian Prick.
Likely a separate issue. I'd lay money on it being an ABS sensor.
http://www.bimmerforums.co.uk/forum/...ensors-t68402/
Here's how to test them.
Old 03-25-2013, 03:29 PM
jamesyboi jamesyboi is offline
Mein Auto: 316i coupe
hmm mine doesnt seem to have any of the above problems
just jammy or start saving ?
Old 03-26-2013, 08:28 AM
Thanks that is very helpful. Now if this damn snow would go away so i can get the car out and see if this works.
Old 05-07-2013, 07:26 AM
The front window fogs with 30 seconds on a day with any humidity.
Old 05-07-2013, 04:24 PM
B1MM3R's Avatar
Jesse Moon Bayne
If one fuse blows you never know what else could go wrong b/c of the crazy wiring being different per vehicle.
Jesse
2001 330i DD
Old 11-26-2013, 07:40 PM
ivantxu ivantxu is offline
Mein Auto: 325is 1992
keep it up!
Thanks, this is my first car and is a BMW 325is 1992, I've been dealing with some of those issues, all of this thread should be in some manual, respect my friend!!!!
Old 11-26-2013, 07:45 PM
keep it up!
My first car is a BMW 325is 1992. All you posted here is REALLY helpful. Thanks a lot, you are making a better world!
Old 11-29-2013, 03:38 PM
Igec Igec is offline
Mein Auto: 95 525i
Just got a 98 328is (Carlos), about a month ago, mint shape with 160km. Sold our 95 525i (Carley) that we had for 7yrs was starting to need more body repairs than I wanted to get into...anyway I did my first oil change on the 328 today and the previous owner gave me all his past bills for work he had done and was changing oil every 5,000km city driving for less than I can buy oil & filter. I dumped the oil and went to remove the filter and she was stuck on there good, had to use a breaker bar and gently get it loose I was afraid it was going to break the housing it was that tight, the filter was clogged up worse than any I've seen,
gotta feeling that's why the changes were so cheap. Filled it back up started the car and rechecked the oil, filled it back up to the level and it would not start...I've done a cabillion oil changes and I'm not new to bmw, corvette etc and never had this happen...neighbor comes over and figures the oil reset is the prob. I figure what the heck, so I short out 7 to 19 and turn ignition to acc and no lights come on so I let it sit for 10sec or so and take off the jumper...car still won't start. Anyway after leaving it for a smoke and beer it fired rough but then smoothed out and is back to normal. I now have no service lights at all were as with the 525 when I reset I have all the bars back on the dash is that normal for a 328 or did I screw something.
Old 01-18-2014, 01:47 PM
93bimmerguy 93bimmerguy is offline
Mein Auto: 318i
Yep, e36s and all their cluster f=== greatness lol
Old 02-21-2014, 07:03 PM
Rtc3 Rtc3 is offline
Mein Auto: E36 m3
dont know how to post on this so everyone can see
how do I post pics and things id like to sell on here very confused ??
Old 03-26-2014, 08:56 PM
New 93 325is New 93 325is is offline
Mein Auto: 325is e36
New guy here....funny stuff but lots of good info! Thanks!
Old 03-28-2014, 09:17 AM
hornhospital's Avatar
D'oh, You Kids!
For sale items go in the classified forum. Toward the bottom of the forum index.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 04-09-2014, 06:34 AM
aamayzingg aamayzingg is offline
Mein Auto:
Good Morning! 325i, 5 speed beauty! 23 year old woman caring for her! TIPS SUGGESTIONS PLEASEEEE Click image for larger version
Old 04-09-2014, 08:27 AM
D'oh, You Kids!
1) Welcome to the fest!
2) You have nice hand(s)!
3) read the stickies at the top of the forum index (cooling system 101; oil guide for your E36; buying and E36, etc.)
Quotes to live by:
Similar Threads
Help My car is doing funny things Skip Molen 7 Series & 8 Series 2 10-08-2005 04:44 AM
It's funny because it's true! ff Off-Topic 26 08-24-2005 11:45 PM
Your funny funny for today that is so retarded only Sabrina will find this one funny. Jever Off-Topic 14 07-30-2005 04:50 PM
Funny, if true... geomax Off-Topic 1 09-23-2002 11:26 PM
