Old 03-26-2013, 09:17 PM
neilsarkar neilsarkar is offline
BMW aficionado
Mein Auto: 750i
This just in: BMW Apps now supports four more apps
This is exciting news for me, since I am a heavy user of Apps. The newly supported apps are Glympse, Audible, TuneIn, and Rhapsody. Those will join the ranks of Pandora, MOG, Stitcher, and BMW connected.
http://engt.co/15SxEId
2015 750i | Dark Graphite | Black Napa | Anthracite
2013 535i | Alpine White | Black Dakota | Anthracite (retired)
2011 328i (retired)
BMW CCA Member 498664
Old 03-26-2013, 09:32 PM
Mr. Grumpy's Avatar
Mr. Grumpy Mr. Grumpy is offline
BMW Enthusiast
Mein Auto: 2017 540i xDrive
That's some great news, I love the TuneIn radio app. Good bye Sirius.
2017 540xi Carbon Black Metallic | Black Dakota Leather w/Blue stitching | Gray Poplar Wood Trim | ZMP | ZPP | ZCW | ZDA | ZDB | ZDT | 668 | 6CP | 6U8 | Black Kidney Grills
Retired: 2011 535i Imperial Blue | Oyster/Black Interior | Anthracite Wood Trim | ZSP | ZPP | ZP2 | ZCV | 2TB | 6NF | 6NR.
Old 03-26-2013, 10:10 PM
BMW aficionado
Mein Auto: 750i
I have never used TuneIn. Is it better than the web radio component of BMW Apps?
2011 328i (retired)
Old 03-26-2013, 10:30 PM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
well most stations on bmw apps web radio only streams 32kbps which is worse than regular FM
Old 03-27-2013, 07:54 PM
Nison's Avatar
none of them work on my CIC, maybe it's NBT only, 2013 crews please test it out
Old 03-27-2013, 09:54 PM
BMW aficionado
Mein Auto: 750i
This is just a press release. Wait till the apps themselves are updated.
2011 328i (retired)
Old 03-29-2013, 02:05 PM
apw2607 apw2607 is offline
Mein Auto: 2009 X5 35d
TuneIn already power the web radio component of BMW connected app.
Goto the BMW app and goto settings > information.
There is one change that will happen though using tunein radios app directly. It will support more radio stations.
Web radio in BMW connected does not support WMA streams. The tunein radio app does.
You will also get cover art depending on the show you are listening too. Why BMW didn't just update the web radio component is beyond me ... But something tells me BMW are trying to move ownership of apps to the app owners themselves and loose the dependency.
That's fine but until they figure out a way to automatically launch a app from the car interface that currently isn't running the whole system is flawed and quite frankly dangerous. This is somewhat of a stop gap anyway.
The next iteration of idrive connected features will see more feature rich apps (beyond those within bmw assist or bmw internet) exist on the cloud and you will no longer need the smartphone for apps directly.
Old 03-29-2013, 02:16 PM
ausdude's Avatar
ausdude ausdude is offline
Mein Auto: 2013 BMW 550i M-Sport
Thanks for the info. I'm a music freak and heavy app user
Untitled[/url] 550i M Sport|300|LCSW|4MR|2TB|704|760|PDC|ZEC|6F2|ZDA|5AD |416|494|Dinan Stage 2|CF Spoiler,MirrorCaps&Splitter|M Performance Diffuser|Front Reflector Delete|Black Grilles|Rear Fog Lights|Euro Side Mirrors&Tail Lights|M5 Front & M550D Rear Sway Bars|20" HB04|Roof Wrapped|Coded|CCA member
Old 04-02-2013, 07:56 AM
pal joey pal joey is offline
Mein Auto: 2012 535xi m sport
my car came with bmw apps.
i have yet to use the feature.
i am considering both the cost and conveniece of what i am now using,and what i would use with the bmw app tunein.
let me see if i have this right.
first step is to install bmw app on my iphone 5?
i went there a couple of days ago and saw a ton of negatives for the app.
so i backed out.
so after i install the app. on my phone
every time i enter the car i need to have the phone on and set to what?
what do i neded to have the car set to?
will it be a wireless or wired connection from the phone to car?
if it works through bluetooth it will be draining down my phone battery.
to those who been using it, what affect has it had on phone data useage?
i currently have sirius for $25. every 6 months.
i have no idea was 6 months of cell phone data would be.
aside from the cost im also interested in the convenience factor,and the musical programming.
Old 04-02-2013, 08:41 AM
cordoor's Avatar
cordoor cordoor is offline
cor door sedan
Mein Auto: 2013 550i xDrive
so i backed out.
To get started:
1. Install BMW Connected on your iPhone.
2. Install MOG on your iPhone.
3. Connect your iPhone to the USB connector in your car.
4. Start the BMW Connected app.
5. Start MOG.
6. Press the Media button on your iDrive controller.
7. Select MOG from the list.
8. Use MOG on your iDrive.
What happens next:
If you do not lock your phone, then BMW Connected stays on and you can connect and disconnect your phone from the USB connector and still be connected. So if you exit your car and come back to your car and want to use MOG:
1. Connect your iPhone to the USB connector in your car.
2. Assuming you did not lock your phone, start MOG.
3. Press the Media button on your iDrive controller.
4. Select MOG from the list.
5. Use MOG on your iDrive.
If you leave your phone in your car (either on purpose or by accident), when you get back into your car, MOG will immediately begin playing again, but the iDrive display will not be inside the MOG app for some reason (I think this is a bug). So these are the steps:
1. Press the Media button on your iDrive controller.
2. Select MOG from the list.
3. Use MOG on your iDrive.
These same steps apply to Pandora. I have not used any other app than these two on my iDrive.
Generally it works. It's not as seamless as it should be, but it works. I really like using MOG to play an artist channel (where it will randomly play songs from only one artist regardless of album). And I like the specific variety of Pandora. So I think it is a win to have the apps feature.
Regarding data usage, I am a grandfathered AT&T unlimited user. But you will pay something like $10-$15/month for an extra 2GB with Verizon so it isn't much even if you need more. And I would be surprised if you used 2GB more of data by listening to music through your phone.
Hope this helps.
-Corey
Current: 2015 i3 REx | Giga | Ionic Silver Metallic
2013 550i xDrive M Sport DHP | Jet Black | Venetian Beige | Dark Red Sycamore
2008 535xi Sport | Jet Black | Cream Beige | Burl Wood
Old 04-02-2013, 11:47 AM
corey...thanks for taking the time to type it all out.
no i do not lock my phone .....what is mog?
i have a family plan for data. currently have 4 gb will soon increase it to 6.
i guess i have nothing to lose by trying the above steps.
im sure once all the install steps are in place ,the remaining steps are then reduced,everytime i enter my car and want music.
i found this video on mog,and pandora...the free version is all that is needed? they also have basic,and primo.
http://cnettv.cnet.com/bmw-mog-inter...-50119035.html
Old 04-02-2013, 11:53 AM
cordoor's Avatar
cor door sedan
I can't remember if MOG lets you use the phone app without paying or not. I know you have to pay to get the 320 bit rate. It's $5/month or something like that.
I like music too so don't mind paying $5/month here or there for good services like Pandora and MOG.
Old 04-02-2013, 12:04 PM
i also like music and dont mind paying a nominal fee for the service ,which is what i have been doing with sirius.
at $25. for six months its like 5 bucks a month when you include taxes.
im satisfied with their musical library and selections. and all i need to do when i want music is push the on button.
im somewhat concerned going with the app is gonna be more steps.
and might possibly be equal to or be more money,depending if there are any monthly fees in addition to data useage.
