Old 03-26-2013, 08:20 PM
sgregor sgregor is offline
Mein Auto: 2004 545i
Smile G'Day!
Hello all! I just purchased a 2004 545i, and am very happy with it! I'm the Parts Manager for McLaren San Francisco and will be taking advantage of our service bay to do complete fluid changes. A couple of questions:
1. What do you all recommend for differential oil. I have purchased Royal Purple 75w90, is this a good choice?
2. I don't subscribe to the "lubed for life" deal. I have Pentosin AF1, is this correct for the auto trans? The car 123,000 on it.
3. Will also be replacing the timing chain tensioner. Having read many of the posts, I think this is a prudent move!
Thanks for the feedback in advance,
Stuart
Old 03-26-2013, 09:48 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Welcome
Old 03-26-2013, 10:05 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
I agree on 2 and 3, very prudent, especially 3.
Will let others comment on 1.
My timing chain tensioner on my 99 540 broke at 125k miles. HUGE rebuild required. Almost sent the car to salvage. Luckily it is still running with new owner who babes it.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 03-27-2013, 08:56 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Welcome and congrats on the ride.
On 1) I used Royal Purple in my old 530 - 75W90 as well. I like Royal Purple products
2) Agree completely about the "liftime" trans fluid, however, most mechanics will recommend that if the fluid isn't changed before 100k miles then don't bother. Fresh fluid after that may do more harm than good.
3) All maintenance is prudent, it will always be cheaper to properly maintain a car than repair it, this is especially true with BMWs and every other high end car.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-28-2013, 12:24 PM
patrick_y patrick_y is offline
Mein Auto: 2004 BMW 545iA
Welcome Stuart!
Old 03-28-2013, 12:28 PM
schpenxel schpenxel is offline
DIY'er
Stuart
1 - that's probably fine. I haven't seen many people change the diff fluid (although it should be changed I'm sure
2 - agreed. RESET TRANSMISSION ADAPTATIONS AFTER YOU CHANGE THE FLUID I personally would (and have) only used ZF's transmission fluid. I don't think mixing it with other kinds is a good idea (you cannot get all of the fluid out by draining alone as the torque converter has quite a bit in it)
3 - that's a good bit of work I'd think, and I've never seen one break. I do know they had a design change on that part later on, so there is probably a good reason that it changed (and that alone may be a good reason to change it). Do you have any reason to change it other than just to be sure it doesn't give out?
Old 04-03-2013, 05:33 PM
Thanks!
Thanks for the input, most appreciated! Replaced the diff oil, Royal Purple! Replaced the transmission fluid, it had not been changed ever! Put in Pentosin ATF1, seems to shift more smoothly, maybe just me wanting it too.
On the tensioners, yes, tensioners. There are 2 timing chains on the 2004 545i N62 motor, thus two tensioners. One for each bank. One is on the top of the motor by the right (from the front) cylinder head. The other on the left side of the motor (from the front) beneath the left clyinder head. Am planning on doing that tonight. I'm doing it mainly because I work at McLaren San Francisco and liive is Stockton, CA, a 160 mile round trip every day, and two, we just sold two cars, both 03 and an 04 545i that lost timing chains in a short amount of time. Sooooo! Wish me luck!
Old 04-03-2013, 05:40 PM
That is a long commute Stuart!
Good luck!
Old 04-03-2013, 05:55 PM
DIY'er
Didn't know they made a 2003 545i..
How many miles were on them? I'm at 190K, but if this is a common failure at high miles then I'll change mine as well.
Old 04-03-2013, 06:16 PM
racooper3 racooper3 is offline
BMW Master Wannabe
Mein Auto: 2005 BMW 545i
2004 MY were likely started in Sep/Oct 2003 and some of the earliest of the N62 e60. I'll be looking into this job in about 60K mi.
Old 04-04-2013, 04:28 PM
Top tensioner done!
OK, did the top tensioner last night, right bank, took me 20 minutes! Would have done the bottom but engine too hot. Will try the bottom, left bank, tonight. Will let you know how it goes. I'll probably have to go in from underneath. Will rack it up and let you know. By the way the other tensioner/guide rail that failed was a 2003 X5. Sorry about the misunderstanding!
Old 04-04-2013, 04:52 PM
Miles
Mine has 126,000. Folks I've talked with seem to think that anywhere from 100,00 to 140,00 is good. After that probably too late. I don't know guys, with this stuff and all the oipinons, hard to know. What I do know is they are cheap enough, probably good to do for peace of mind.
Stuart
Old 04-04-2013, 05:47 PM
DIY'er
I would be interested in a little more info about what all you had to do to change it.. if it can be done that quick, I'm changing mine too
Old 04-18-2013, 09:21 PM
Tensioner Change and Trans service
OK, I did service the transmission. Removed the pan and installed new one OEM BMW. Took me about an hour. Used Pentosin ATF1. All good, shifts great. On the tensioners. As of my last post, did top tensioner, right bank from the front, 20 mins, the bottom tensioner, side left bank front, is NOT possible without dropping the front cross member and dropping the motor down on that side. Not sure how much twist the exhaust system would take. Huge job, have not yet done it! Wasted 2 hours trying! Will probably need three to four hours, even then I'm not sure it's the way to go. I do know I do NOT want to take the motor out! If anyone has done it, love to know how you did it!
Did a muffler delete! Tried it for a week . . . too loud. Heavy harmonics from 1,500 to 2,100 RPM. Took back to shop, added a magnaflow . . . nice!
Software update! Is there anyway to know if the car has the latest updates?
Thanks all,
Stuart
Old 04-19-2013, 06:39 AM
DIY'er
Thanks all,
Stuart
What did you have to pull to do the right bank tensioner?
http://www.bimmerfest.com/forums/sho...=417251&page=5 is a pretty decent thread on pulling the motor apart
