Old 03-28-2013, 12:44 AM
Felishad1968 Felishad1968 is offline
Send a message via Yahoo to Felishad1968
Mein Auto: BMW 530i
Unhappy 2005 530i
The last 3 months, I have been having difficulty with my car starting. I have gotten a new battery and a new starter. Initially after I got the new starter, I had no problems. Now, it takes a while for my car to start. It's been pretty cold, so when I leave the car sitting in the garage overnight, it takes about 6-10 key turns, before it actually turns over. It runs fine and if I run into a store, it cranks right up. However, when I go into work, and come back out after 10 hours, its difficult to start again. Any ideas?
Old 03-28-2013, 02:09 AM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Have you tried changing the oil?
Do you have rough idling?
I had a similar problem a couple months ago with my E39 which i believe have the same engine as yours (Almost the same, its a 2.5L M54) and it was due to the CCV valve. I had rough idle and the exact same issue as your, car would need 2 - 3 attempts before it started after i left the car overnight or for a long period but if it was still warm it would start up immediately.
Old 03-28-2013, 12:44 PM
Mein Auto: BMW 530i
I get my oil changes every 5,000 miles faithfully. I have another 1,000 miles until the next one is due.
Old 03-28-2013, 05:12 PM
Mein Auto: A Car
It could be so many things, injectors, spark plugs?
Old 03-28-2013, 05:23 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Without a rough idle I am stumped. Have you checked the voltage regulator and/or alternator?
I had issues with my 2005 530, but they all involved VERY rough idle. It was actually the fact that the oil separator had cracked in half.
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
