Old 03-30-2013, 05:35 AM
Bellarose Bellarose is offline
Account closed at users request
Mein Auto: BMW 2001 Z3 2.5 I
2001 Z3 - Subwoofer
Any suggestions -- My subwoofer sounds like it rattles like its blown. I check it out can not see any problems. looks like a 5 inch speaker and a box behind it. Has any one replaced the subwoofer or same problems Im having ?
Old 03-30-2013, 05:51 AM
jcard412 jcard412 is offline
Mein Auto: BMW Z3
I had the same problem. Now this may seem silly, but I just wedged a piece of foam up against the speaker and it stopped the buzz and it sounds fine. Since I'm not an audiophile, I really can't hear the difference especially since the top is down most of the time and the wind is blowing past my ears at a high rate of speed.
Old 03-30-2013, 07:26 AM
Mein Auto: 1998 Z3 Roadster
This has been discussed many times and there are many threads on it. Repairs range from adding silicone to the speaker cone to replacing the speaker with a ComptVT65 Kicker.
Near the top of the page, on the right, is a button called "Search This Forum." Click that and enter "subwoofer" and you should see lots of ideas.
Note that pre-2000 cars had two 5.25" subwoofers while post 2000 had a single 6.5" subwoofer, which is the more desirable version. As you look through the threads, you can ignore the ones based on the earlier design.
Old 03-30-2013, 02:53 PM
JackDuggan JackDuggan is offline
Mein Auto: 2001 Z3 3.0 Roadster
When I bought my 2001 the subwoofer was OK, but the kick panel speakers were both blown. I used the silicone caulk fix that people use on the subwoofer.
Old 03-31-2013, 02:59 AM
Z3 Subwoofer
Thank You -- great information.
Old 03-31-2013, 05:08 PM
kmassey kmassey is offline
Mein Auto: 2001 S54 M Roadster
Sent mine to Orange County Speaker...I think it was $65.00 for a new surround. Sounds great now. My experience is that the silicone will only last a while. The surround becomes too brittle to hold the caulk.
Old 04-01-2013, 11:27 AM
AustinZ3 AustinZ3 is offline
Teenage Speed Demon
Mein Auto: Z3 2.5i Roadster
I had the non-HK subwoofer in my Z3 but being 17 blew the foam surround and then blew the second one we fixed it with. I ordered a HK subwoofer box off ebay and trashed its blown 6.5" subwoofer. Then bought a Kicker CompVT6.5 and followed a tutorial on here. Ill post a ling below. All in all, i Paid $150 and it is WAY better than what i had. Soon as i upgrade everything else it will be even better.
http://forums.bimmerforums.com/forum....php?t=1373769
2001 Z3 2.5i, Spyder Halo Headlights, Kicker CompVT65 Subwoofer, LEDGlow Million Color Underglow Set
