E30 (1982 - 1993)
Old 03-27-2013, 09:49 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
Parking light issue?
Hello guys, BTW my name is Marcus (if anyone cared) plan on sticking around here for awhile. But thats all beside the point. Here is the scenario, I was driving home tonight and I noticed my brake lights weren't working (they worked just fine a couple days ago) when I couldn't see them in the reflection of the car behind me. So I pull over and sure enough they don't work. I pulled both light housings and the bulbs are fine. I check the fuses according to the bently manual. Those are fine. So I have that narrowed down to a possible bad brake switch (I hope, it is the OG unit)
Ok thats all good now. So i shut off the car at home. Then I had to leave again. So i turn on the lights and now my dash lights are out as well as the licsense plate lights and the right tail light. Ok so i check the bulbs and they are fine. I checked the fuses again per Bently and they are fine. However When I re inserted the fuse and turned the lights back on all the lights worked again. Ok yay! But no i flicked the lights of then on again and sure enough the entire right side (front and back) parking lights along with the cluster and plate lights are out. Now with a quick glance in the bently it seems as though these lights pass through the headlight switch (obviously lol) and i know it is faulty. Would this switch cause only the left side lights to work an not the right side?
Sorry for the novel I jus wrote, thanks for the help.
Old 03-28-2013, 12:23 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Yes, a bad light switch could cause this problem but the fact that your symptoms change when you re-plug the fuses would point to corossion in the fuse box which means removing fuses and cleaning all the contacts.
Old 03-28-2013, 08:33 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Could also be a loose ground somewhere.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 03-28-2013, 12:34 PM
First time's Avatar
Well I don't think a bad ground is the cause for just the right side not to be work. At least I hope not lol. Ima try and locate a switch at my local junkyard today or tomorrow.
This morning the parking lights worked fine (the brake lights still dont work though) so I am leaning even more towards the headlight switch.
Old 03-28-2013, 07:08 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
I think Bill is on to something there. When I got my 87 325e last year, I fixed many of the electrical issues by simply cleaning the terminals on the fuses, relays, switches, bulbs, ect. A few minutes with a wire brush and a small file really goes a long way on an older car. I hope it helps
Old 03-28-2013, 07:48 PM
First time's Avatar
Odd, today everything worked fine
Old 03-28-2013, 08:24 PM
woodenbmw's Avatar
After close to 30 years it can't hurt to clean everything up a bit.
Old 04-01-2013, 05:09 PM
First time's Avatar
Well I pulled my headlight switch out to find that three of the contacts are burnt. Also the female connectors are burnt as well on the wiring loom side (chassis wire harness) I am not sure what could have cause this but now my lights are out again for good. They have been for the past couple of days. I went to the junkyard today to look for another switch and of course there were no e30's in sight. There was one e21 which i promptly took the switch for (just grabbed it as it takes no tools anyway) just to match it up against mine and they are completely different. I might be able to make it work though if I have to.
Right now I cant justify spending $120 on a new OEM switch from pelican. I will check back at the yard some other day before I go modifying the e21 switch to work with my car.
Here are some pics of the damage:
ID:	369326   Click image for larger version
ID:	369327   Click image for larger version
Old 04-02-2013, 04:50 AM
You should be able to get the E21 switch to work. If the connector to the switch is different to the E30 connector then when you next go to the junkyard, cut off the E21 connector with a few inches of able attached to use on the E21 switch.
Old 04-02-2013, 06:40 AM
First time's Avatar
Yea thats what i was going to do. But there is one extra wire on my car vs the E21. Also (although im sure they are similar switches in nature) a couple terminals are different. I will just try and go back to find the correct switch or order a new one. I dont fancy hacking up my harness just to ghetto something up.
Old 04-03-2013, 08:00 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
I have seen this often when people fit high-watt bulbs/spotlights without running them through relais.
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 04-08-2013, 05:40 PM
First time's Avatar
Well replaced my headlight switch and everything is functioning properly as of now.
