Water Pump Debris - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-02-2013, 06:32 PM
jmana jmana is offline
Mein Auto: 98 328i
Water Pump Debris
I need some advice on how to get a chunk of a water pump impeller out of my engine The impeller is a composite one, so it broke into about 9 fairly large chunks, and I put it back together to see if any were missing, and it's just my luck, there is one piece about an inch in size that is MIA. I used a shop vac to suck out where the water pump was, and that's how I got the other chunks out. I also took a garden hose and put water in where the thermostat is, but just water came out, no missing chunk. I tried finding the drain on the side of the block, but I couldn't seem to locate that I guess it would help knowing how the water flows through the system, so I know which direction it would have went, and then apply water pressure the opposite direction somehow. Any advice would be greatly appreciated!
Old 04-02-2013, 06:37 PM
hornhospital's Avatar
D'oh, You Kids!
Do you have access to compressed air? You could try blowing it out, but you'll have to figure where to apply the pressure so it doesn't force it further in. I can't help you there....
Are you sure it's not in multiple pieces in the radiator or hoses?
Quotes to live by:
BMW-CCA #441426
Old 04-02-2013, 07:17 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Or maybe try hooking up a shop vac to the water pump inlet? That way it will suck whatever is in there from whence it came, rather than potentially moving stuff further inside.
1998 BMW 328is
1966 Pontiac GTO
Old 04-03-2013, 11:09 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I wouldn't use it for this particular problem, but as for the block coolant drain, it's under the exhaust manifold. BEWARE: the bolt is quite short, less than half an inch or so. Don't let it catch you unaware and shower you with coolant. Ask me how I know...
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 04-03-2013, 12:52 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
How do you know?
I been through this as well.
Old 04-03-2013, 12:57 PM
E36 Phantom's Avatar
I Am The Machine
Any errors in this post are purely Swype's fault, not mine.
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 04-03-2013, 01:04 PM
Leusent Leusent is offline
Mein Auto: 328is
Eff that stupid short bolt.
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
