E36 (1991 - 1999)
Old 04-04-2013, 03:03 PM
madyicstik madyicstik is offline
Mein Auto: 1995 bmw 320i
what does the number on your wheen means??
i have a style 42 and i need to find out what do those number on it mean. all i know is i run 265/35/18 on my rear and i get a little bit of rubbing.
on top of my wheel i can see18/23x18EH2 in between the bolts what does this mean? im assuming this is the size?
another question is i have another set which 7x17 right now it has 205/50/17 on it and i want my rubber to go wider... how wide can i go with wheel that has 7x17???
Old 04-04-2013, 03:09 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
The widest I would suggest on a 7'' wheel would be 225
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-04-2013, 03:22 PM
Thanks for your quick reply b1mmer... what woudl happen if i go wider?
Old 04-04-2013, 03:36 PM
B1MM3R's Avatar
Jesse Moon Bayne
The sidewall of the tire would probably flex/bubble out too much.
Jesse
2001 330i DD
Old 04-04-2013, 04:05 PM
Thank you sir! How bout for my other question? Is it possible that 18/23 is actually. 18x9?
Old 04-04-2013, 04:10 PM
B1MM3R's Avatar
Jesse Moon Bayne
it should say 18x? and also have et?? for the offset.
Jesse
2001 330i DD
Old 04-05-2013, 07:20 AM
if its 18x23 if 23 is in centimeter it be alittle over 9 inches.. so is it possible that its 18x9??? my front wheels says it on them it says 8jx18 so im assuming its 8x18? if im going to measure the wheel widht am i measuring from the outer lip to outer lip or the inner part of the lip?
Old 04-05-2013, 09:13 AM
B1MM3R's Avatar
Jesse Moon Bayne
Its possible.
Jesse
2001 330i DD
Old 04-05-2013, 10:32 AM
hornhospital's Avatar
D'oh, You Kids!
Width is measured inside lip to inside lip. Diameter is bead seat to bead seat (you didn't ask, but I threw that in there for free )
Quotes to live by:
