E30 (1982 - 1993)
Old 04-04-2013, 09:44 AM
Scartissue27 Scartissue27 is offline
Driving is everything
Mein Auto: 540i//E30//E36
Timing Belt help????
Members:
I'm having a minor issue replacing my 1990 325is timing belt. Mind you I have performed this job before on my 1987 325i 4dr without any issues. However, as I got closer and closer to the timing belt on my 1990 E30 it appears the crankshaft pulley and the harmonic balancer are one solid unit . I was quite surprised when I removed the 22-mm bolts and the pulley to find the toothed timing wheel behind it. To make a long story short I cannot get it off to finalize the job?? Any suggestions or tips would be greatly appreciated.
As a side note, I purchased the 101 Performance Projects for you E30 and also attached a picture can you notice the difference?
Name:	90 E30 garage.jpg
ID:	369627   Click image for larger version
Name:	90 E30 engine.jpg
ID:	369628   Click image for larger version
Name:	90 E30 engine 2.jpg
ID:	369629   Click image for larger version
I Love Haters!
Old 04-04-2013, 10:52 AM
hornhospital's Avatar
D'oh, You Kids!
Nylon hammer carefully applied. It's still a two-piece part. The toothed wheel is the crankshaft position sensor ring.
Quotes to live by:
BMW-CCA #441426
Old 04-04-2013, 11:26 AM
Excellent! I'm going to give this a shot thank you in advance.
I Love Haters!
Old 04-04-2013, 12:35 PM
Awesome!
Thank you it worked precisely!
However, I managed to find that the previous owner left the center bolt loose that turns the crank . I'm surprised this didn't change the timing of the vehicle or did it?? Please take a look at the picture I posted.
According the the book it looks okay, I may need to rent an air compressed deep socket to re secure the crankshaft bolt this is CRAZY!!!!! it looks like someone didn't know what they were doing.
I Love Haters!
Old 04-04-2013, 12:37 PM
Oh and I did put the engine in TDC notice the marks
I Love Haters!
Old 04-04-2013, 06:47 PM
downhiller's Avatar
livin large
that main bolt being loose wont cause major problems like out of timing, since there a key in the crank. to could however come loose while driving and cause more fun.
quick way to tighten it without air tools, put in tranny in 4/5th gear. chock all four wheels. torque bolt.
Old 04-04-2013, 07:15 PM
D'oh, You Kids!
Good idea on the center bolt, downhiller.
Scartissue27, did you turn the crank 2 full revs and then set the belt tensioner?
Quotes to live by:
BMW-CCA #441426
