Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - Current)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 04-02-2013, 05:30 AM
unlaidenswallow unlaidenswallow is offline
Mein Auto: 650xi vert
Originally Posted by Bönz View Post
I tapped the power for my V1 from the fuse panel behind the glove box. Ran the power up the A pillar, across the header to the detector mounted on the passenger side of the rear view mirror. The detector is tucked up high between the mirror and the windshield. The rear facing receiver has a clear shot thru the back glass.
I ran the remote wire under the dash, past the cup holder (behind the trim), under the steering column to the remote. It's mounted low, with velcro near my left knee under the light switch. I have a clean sightline to the remote. I can take some pictures if you like.
Although I changed it up some, there's a great post somewhere that I used as a guide, but I can't seem to find it now.
Referring to this one?
http://www.bimmerfest.com/forums/sho...d.php?t=602409
Works great - and saved me multiple times...
2012 650i xDrive Vert - Mojave / Cinnamon
Driver Assist / Cold Weather / Premium Sound / Luxury Seating / Leather instrument panel / Apps
Old 04-02-2013, 05:53 AM
jsherm jsherm is offline
Mein Auto: 650i
Thanks for link! Very good DIY!
Old 04-02-2013, 09:47 AM
Bönz's Avatar
Bönz Bönz is offline
Mein Auto: 2015 M5
YES! That's the one. This really helped me out, except I managed to avoid the exposed wire near the top of the A pillar by tucking it behind. Also, since the V1 has a larger remote display, I located it under the headlight switch. This keeps it hidden from passengers and maintains a cleaner look on the console. My detector is pretty much in the same place in relation to the mirror.
Old 04-02-2013, 02:32 PM
Awesome - was hoping it would help someone! Like the improvement behind the A pillar... remote on the left is probably better too but I either ran out of cord length or energy to figure out how to get it on the other side of the steering column - or both...
Old 04-03-2013, 04:21 AM
Bönz's Avatar
Mein Auto: 2015 M5
Thanks again. Even with your guide, the effort was such that pausing to take pictures and write instructions would have been too time consuming. It made me appreicate the effort you put into your guide. It's guys like you that really make these forums valuable.
Old 04-03-2013, 05:48 AM
AVB-AMG AVB-AMG is offline
Mein Auto: '16 BMW X5M & M-B ML63AMG
Custom Installation
For those of you who want the most effective and clean looking installation of a radar detector and laser shifter system, I recommend you consider the following.... A custom installed ESCORT Passport 9500ci system with the display mounted inside the OEM interior rear view mirror. It is expensive but if your driving habits and travels expose you to expensive speeding tickets, the system will pay for itself very quickly. Here is the link to another thread in another forum that explains the system and setup.
http://www.bimmerfest.com/forums/sho...errerid=313632
AVB-AMG
2016 BMW X5M (Daily Driver)
2014 BMW M6 Coupe (leased, returned)
2007 M-B ML63 AMG (Wife's Daily Driver)
2013 BMW 335 xDrive Coupe (leased, returned)
1961 M-B 190SL (Fair weather weekend treat)
2004 M-B E55 AMG (leased, returned)
2004 BMW X5 4.4i (leased, returned)
2001 BMW X5 4.4i (leased, returned)
2000 M-B E45 Sport (leased, returned)
Old 04-05-2013, 08:59 PM
svp66 svp66 is offline
Mein Auto: 650i
Got a V1 4 years ago. Best purchase I made - no tickets. I did turn of POP mode because of the blind-spot detector, easy to do and so far no problems in 3 states. I get probably a mile or so warning through the normal windshield. Never bothered to have it professionally mounted, it goes very nicely with the provided clip on the sun visor. I use it only for long drives, so I don't mind not having it permanently installed
Old 04-12-2013, 10:08 PM
todthebod todthebod is offline
Mein Auto: '08 535i
Just to add my two cents.............a V1 and trapster. If you're really feeling froggy then a hidden jammer with a kill switch that'll give you time to brake before they get a reading on you.
Old 04-13-2013, 09:29 PM
The Wine Guy The Wine Guy is offline
Mein Auto: 650I; F430, R1200RT
I've got a Valentine and have not been stopped since I got it 12 years ago.
