Old 04-05-2013, 11:34 AM
01tj 01tj is offline
Send a message via AIM to 01tj
Mein Auto: E46 330i
Time for new brakes
Any recommendations? Its an 02 330i with ~43,XXX miles and I'm guessing they are the original pads and rotors. I need to go pull the wheels and find out if its the fronts or rears but I want to have an idea on what I should get. Also do you guys usually replaces the pads and rotors? Any idea when the light usually comes on, i.e. do I still have some time before they need replaces?
Thanks guys
Old 04-05-2013, 12:07 PM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
From what I remember, you have about 1,000 miles after the light comes on... but I always do it when it comes on and not push it. But, it doesn't really matter since you have to replace the pads and rotors every time anyway. I used ceramics last time, and I will not use them again... they are too soft for me, they don't fade but the OEM bite is not there.
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 04-05-2013, 12:16 PM
ECSTuning's Avatar
ECSTuning ECSTuning is online now
Instructor of the Stig™
Our stock type replacement kit (LINK) with Meyle rotors and Vaico pads has been getting good feed back from customers. It provides you with coated rotors (to protect against rusting and corrosion) and Vaico pads which are similar in characteristics to the stock pads.
If you wanted to switch to a low dust pad I'd suggest making the move to Hawk HPS, they are a performance upgrade for your car and a great all around pad. We pair them in service kits with oru ECS GEOMET slotted or drilled and slotted rotors (LINK).
If you choose to go with individual components and pick your own package basically keep in mind because the wear sensor has tripped you'll need to replace it as well. I've found MTC and Uro sensors (LINK) to be great, they are budget friendly and get the job done.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 04-05-2013, 01:08 PM
Mein Auto: E46 330i
Thanks, any discounts for forum members
Old 04-05-2013, 01:54 PM
jdauria jdauria is offline
Mein Auto: E39 ///M5
OEM BMW Performance Rotors FTW!
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 04-06-2013, 05:17 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
This is incorrect and potentially dangerous. You only have two sensors, not four. One on front left and one on rear right. If , for instance, you have uneven brake wear and your front right is more worn than the front left, the sensor would not let you know that. I recently changed my brakes after the front right got so thin that I had metal grinding on metal. The sensor never tripped.
Change your brakes ASAP. I got OE replacements from oembimmerparts for $110 shipped.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 04-06-2013, 10:19 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
+1 for the OEM parts at oembimmerparts. Just be prepared for the usual large amounts of brake dust. Get Porterfield R4S pads as alternatives for OEM replacements with the stock OEM Zimmerman rotors if you want very low dust, same OEM bite but better thermal resistance, quiet and is the same price.
Btw, this topic has been discussed to death, search is your friend.
Old 04-06-2013, 01:56 PM
Mein Auto: E46 330i
Looking for the most up-to-date info though
Old 04-06-2013, 02:19 PM
mofunk mofunk is offline
Mein Auto: 2004 325ci
I like using an OEM rotors and Brembro brake pads. Brake dust I don't mind because I know my car is working. Plus you can always wash it off. lol
OEM rotors because it will fit best with your car.
Old 06-11-2013, 02:13 PM
dougv123v dougv123v is offline
Mein Auto: 325i
325i needs rotors
Hi Guys,
New to the site and BMW...just picked up my first bimmer a 2003 325i about 6 months ago. the car is in great shape and I love to drive it. But I do need front rotors...got several quotes from Napa from $45 per rotor to $145... the dealer wants $100 per rotor. what's the general rule of thumb when looking for new rotors? What do I need to look for, any suggested brands that I should stick with?
ps: my pads look fine, about 1/2 of the pad is left.
thanks,
doug v
Old 06-11-2013, 02:22 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Originally Posted by dougv123v View Post
Hi Guys,
thanks,
doug v
You don`t replace just the rotors, and not the pads. What makes you think you "need" rotors ? Did you measure them with a caliper ? If yes, what was the thickness ?
The road goes ever onward....
(R.I.P. Jever)
Old 06-11-2013, 02:33 PM
Mein Auto: 325i
I brought it into a shop to try and figure out why the brakes were squeeky, but the warning light failed to go off. the response was...change the rotors.
but that's a good point, i didn't measure the rotors, but did a visual on the pads. they look pretty good to the untrained eye.
any suggestions?
thanks for the answers.
doug.
Old 06-11-2013, 03:06 PM
Fast Bob's Avatar
Keeping it surreal
any suggestions?
doug.
Yeah....don`t listen to the boneheads who are trying to sell you something you don`t really need.
Here`s a DIY you can try, and it`ll only cost you a couple of bucks. Get some anti-squeal compound, and apply it to the rear surface of your brake pads. That annoying high-pitched squeal is usually caused by high-frequency vibration, and the paste (compound) dampens those vibrations.
(R.I.P. Jever)
Old 06-11-2013, 03:20 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Could be the type of pad you're running... do you know the history of the brakes? You should inspect the pads and sensors just to be sure they are what we assume. Someone could bypass the sensor so it will never trip.
Another free trick... hose down the rotors and let them rust over, then go for a drive and do some hard stops - being safe to do this on a deserted road with no one behind you. If there's any gunk built up on pad or rotor, this will scrub it off nicely.
Jeff R.
Old 06-12-2013, 05:16 AM
Mein Auto: E46 330i
Check http://www.ecstuning.com/ and http://www.bavauto.com/ for kits that include pads, rotors and sensors. I would replace everything at once. I can't see why your rotors would go before your pads though. All 4 pads went on my car at once.
