Old 03-23-2013, 09:17 AM
Spikes007 Spikes007 is offline
Mein Auto: 02 325xi ZSP
Dead battery after 2-3 days
I have a problem that I am not able to find where it's coming from. When I don't drive my car for 2 or 3 days, I'm not able to start the car because the battery has been drained. I have 3 leds on my car blinking while the car is not running. I don't see how this can be the problem but I'm looking for a way to test the electrics component to see where's the "leak" coming from.
By the way, the battery is 2 months old and I already did the battery test (from the dashboard) and it seems like everything is ok.
English is not my first language. Sorry for the mistakes.
Old 03-23-2013, 12:18 PM
boltaction boltaction is offline
Mein Auto: 2002 325i
So when you run the #9 obc test you are seeing 13.8-14, meaning your alternator is working?
Old 03-23-2013, 12:26 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
YouTube will usually have what you need, you just have to search.
Old 03-23-2013, 01:29 PM
Yes.
Thank you for the link! I was trying to find something useful but I guess I didn't have the right keywords to do a proper search. I will definitely check that out next week-end!
Old 03-24-2013, 09:30 PM
This is meant to be instructive:
- One users experience diagnosing parasitic dead battery overnight current drain (1)
Old 03-25-2013, 08:14 PM
mofunk mofunk is offline
Mein Auto: 2004 325ci
I had the ac/heat blower drain my battery overnight and during the day. If that helps? Listen when you turn your car off.. if you hear the compartment fan going. My mechanic told me to unplug the battery overnight and the next day plug it back up.
idk if that's what you have ??
Old 03-26-2013, 07:44 AM
Mein Auto: '04 330Ci 6-speed
Take a few of your posts and they are the equivalent of writing shop manuals for us gratis!
First, thanks so much for all you contribute.
Wonder how you find the time and dedication, and if you ever end up with time to drive your car.
Old 03-26-2013, 09:01 AM
SJBimmer's Avatar
+1 on that! bluebee is awesome! She is probably driving more than the rest of us too!
Old 03-27-2013, 12:41 AM
ChipD95613 ChipD95613 is offline
Mein Auto: 325xi, 528i, 535i, 9000
BMW has had to release 2 revisions of the Final Stage Resistor (or "blower motor resistor") due to this problem. If you do not have the most recent revision you will have this battery drain issue. Make sure to update yours. If you haven't, that is most likely the problem.
Old 03-27-2013, 03:27 AM
There is a huge thread on USENET alt.autos.bmw regarding the FSU this week:
- Root cause insight into the common BMW blower motor resistor failures
In addition, here's my detailed story looking for parasitic overnight battery drain:
- Recommended method to diagnose overnight parasitic battery current drain including the FSU (1)
See also:
- How to repair your own final stage resistor for free (1)
And, of course, you'll need this if you're gonna buy a new one:
- What is the right brand FSR to purchase (1)
Your job, now that I've done mine, is to improve the record, so that we move forward, repair by repair, on understanding and fixing the FSU.
Old 03-27-2013, 11:15 AM
2zzday 2zzday is offline
Mein Auto: 2004 325Ci
I have this same problem. Did you ever find a solution?
Old 03-27-2013, 12:10 PM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by sjbimmer View Post
+1 on that! Bluebee is awesome! She is probably drinking way more coffee than the rest of us too!
FIFY....
The road goes ever onward....
(R.I.P. Jever)
Old 03-27-2013, 12:43 PM
SJBimmer's Avatar
FIFY....
Unfortunately, I have had to modify my opinion.
http://www.bimmerfest.com/forums/sho...7&postcount=25
Old 03-27-2013, 02:28 PM
Thank you, Chip. I'll have my mechanic look into that.
Old 04-05-2013, 07:17 AM
I was supposed to do the tests but it was freezing cold this weekend (snowing) so I didn't. But all the symptoms seems to be from the Blower Motor Resistor. For about a year now, when I turn on my fans, the fan isn't regular. Also when I start the car in the morning, I always hear a "pop". I have no idea for how long because I never turn on my fans during summer. And yes I do hear the fan when I put my key in the ignition (without turning the car on). I ordered one and I'll replace it and I'll get the result in this thread. Hope this will fix my fan problem AND the draining battery.
Thank you for the links and tips!
Old 04-05-2013, 10:51 PM
Very likely FSR will cure what ails you.
Old 04-06-2013, 01:07 PM
So I was right. Actually my mechanic diagnose that on my old bimmer. I remember going to work and my car was fine. What I didn't pay attention to was when I went to my car at lunch time and the key remote didn't work. It was working fine when I parked the car. When I came back 3hrs later It wouldn't open with the key. I shook it off at my key have an bad day.
While I saved up to have it installed, I kept unplugging the battery until I had the funds. Its ironic that after my car was totaled I found another Bimmer that's on the early stage of the same symptoms. Luckily the summer is coming. I' do have an extra resister from my last car (long story).
Get it fixed. Trust me you don't want to have no heat in your car in the winter time. Blankets don't help when it's 20 outside lol
Old 04-06-2013, 03:26 PM
Originally Posted by mofunk View Post
I kept unplugging the battery until I had the funds. l
Alternatively, next time you could just pull the blower motor fuses overnight.
Old 04-06-2013, 04:47 PM
Oh sweet. Didn't think about that.
Old 05-21-2013, 08:14 AM
I know it's an old thread but just wanted to post to confirm it worked for future reference.
Changed the FSU last week and it seems to have fixed the problem. Didn't drive the car for 3 days and I didn't have any issue starting the car yesterday. Also the DIY was easier than I thought. Took me 1h (stopped several times to check DIY videos).
Thanks again!
Old 05-23-2013, 03:23 PM
Got the resistor replaced and have had no further issues with phantom battery drain. Thanks to everyone on the thread who pointed me to this solution.
