E46 (1999 - 2006)
Old 04-07-2013, 10:37 AM
dfishfan dfishfan is offline
Mein Auto: 325 CI
yellow brake light
heard a pop when stopped at light, then the hand brake light came on "yellow" and the DSC light came on and stayed on. Brake pedal is now real soft when pressing to brake. Any ideas
Old 04-07-2013, 10:46 AM
boltaction boltaction is offline
Mein Auto: 2002 325i
Pull your back wheel and make sure your P-Brake pads didn't pop out, there's a small pin with a spring that holds pads to the dust guard, that may account for the pop you heard... as far as soft pedal, not sure, hard pedal is normally vacuum related. Soft pedal is more concerning..
Old 04-07-2013, 06:50 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Instead of buying parts, I would say you need to cease driving the car until you inspect your brake system. Start by checking fluid level. Guessing its low. Next step is to check for leaks at the wheels, master cylinder, and under the car.
