Old 03-10-2013, 04:42 PM
mattymetzger's Avatar
mattymetzger mattymetzger is offline
Mein Auto: BMW 645ci
Angel Eyes not working
A few weeks ago I bought these LED lights
http://www.ebay.ca/itm/2x-10W-White-...b01f32&vxp=mtr
After installation they did work but today I took the car for a drive (first time since installation) and I noticed the lights were off. After some investigation I noticed that the lights would flash several times when I start the car but then stay off, I took the lights out and after wiggling on the connections they would come on. So this should be an easy fix - I soldered all connection (there are several as you can see in the pic) except the one that plugs into the original connector on the vehicle, but the lights still don't work. I also tried the old bulbs and they also do not work. Has anyone an idea what is going on here?
20" wheels 245/35 - 285/30, black grill and blacked out side markers, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks,
AC Schnitzer pedals, Sprint Booster (what a waste of money), electronic exhaust cut-outs, red brake calipers (painted)
AFE air intake, door laser BMW logo projector lights, CSR front lip with carbon accents, carbon side skirts
Old 03-10-2013, 05:56 PM
roseng's Avatar
roseng roseng is online now
Have you confirmed that they are currently enabled in the iDrive (yes, even though they were working).
They will flash either way when you start the car.
If so, plug in the old lights and see if they work.
If not then follow the fuses.
Old 03-11-2013, 12:46 AM
Yorgi's Avatar
Yorgi Yorgi is offline
Canadian versions of the 6 series do not have DLR/angel eyes adjustment options in iDrive.
I would use a voltmeter to see if you are getting anything at the plugs and if not check fuses first like roseng suggested.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 03-11-2013, 06:41 AM
Thanks Roseng and Yorgi
before checking the fuses, I thought to just give it another try and when I turned the car on, the lights worked. Not sure what was going on yesterday because I played with the lights for some time and even the old lights wouldn't work. I just hope everything stays the way it is now and the lights keep shining white and bright.
Old 03-11-2013, 11:04 PM
Yorgi's Avatar
That sounds like corrosion on the plugs. Maybe try spraying some contact cleaner on both contacts next time you open it up. (DexoIT is great, your local RadioShack/Source will probably have something similar or WD40 if you are desperate)
'04 M3 - track
Old 03-12-2013, 05:14 AM
roseng's Avatar
Good point. I forgot to look at his location.
Old 04-11-2013, 03:44 PM
when I have the head light switch in auto mode, my angel eyes are only on if the lights are on at night but don't come on with the daytime running lights. I had the car at my Indy to disable the passenger side seat-belt warning and also asked him to change the angel eyes to be on all the time, unfortunately he could not change the light settings and told me he has to look into it. Is this common on older (2004) Canadian vehicles? I noticed several BMWs with the angel eyes off during the day.
Old 04-16-2013, 12:41 AM
janbrasna janbrasna is offline
Exhibition of speed FTW!
Mein Auto: 645Ci / 130i / Z4 2.5i
Yes, that's correct for preLCI models, as the halo rings there (at least EU-spec) are not homologated for DRL use (= are weak, do not have varying intensity and are unusable in sunlight). I'm not sure any add-on as eLCM/LCM2 solves this, I'm afraid you'd need to have the AEs hardwired if you wanna use them as DRLs in auto mode.
Old 04-16-2013, 05:28 AM
Here is a reply I got from Tampamark in the thread DIY Coding your BMW...so simple it is available to all!
He said:
It can't be done with programming. Read this:
http://www.bimmerfest.com/forums/sho...1&postcount=64
OPTION 1: If you want to upgrade your lighting module to accomodate then here is the DIY post just put in yesterday:
http://www.bimmerfest.com/forums/sho...d.php?t=689301
OPTION 2: Use relays per the following DIY:
http://www.bimmerfest.com/forums/sho...14&postcount=1
Old 04-16-2013, 04:05 PM
Great links for reference, thanks mattymetzger!
angel eyes, led
