BMW E39 A/C Pressure Readings Advice Sought - Page 2 - Bimmerfest - BMW Forums
Old 07-09-2011, 03:01 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Originally Posted by bmw_lover85 View Post
Thank you Burning2nd. I don't want to evacuate the system... Is that ok?
I thought I can let some pressure out and then put some oil. My AC is cold... It just make knocking noise from the compressor... It sounds like an impact gun but a little bit lower in sound.
chances are your compressor is on its way out, If you hear a knocking noise already.
technically you put the oil in first.. then the amount of freeon,
when topping off a system the little cans work fine...
I have no idea what will happen if you put oil in a changed system... and ive never heard a compressor knock....Only seen them seize...
compressor for the 5's run like what 500 bucks?
15486372<-----
Old 04-17-2013, 06:13 AM
bmwmanz2 bmwmanz2 is offline
Send a message via MSN to bmwmanz2 Send a message via Yahoo to bmwmanz2
Mein Auto: E39 528i
For the static reading (car running AC off) you need a Pressure Temperature chart or app by DuPont. This will show you what your gauges should be reading. Ie. ambient temperature is 90* the gauges should read 104.3*. For a Dynamic reading (car on and AC running) on your AC Manifold gauges on the low side should read between 25-45 and the high side should read 100-150* above ambient temperature. Ie. 90* ambient temp high side should read 190-240* on the high side. The PAG oil can either be injected via a recovery machine or taking the compressor off and filling it to the correct specs taking off the back plate of the compressor. As for a noisy compressor, this usually means your compressor is bad and has run low on oil. Hope this helps a little guys. Have a great day!
-Tony
Old 04-17-2013, 06:50 PM
I'm gonna cross reference this thread to the canonical AC threads so that this information isn't lost.
- How to learn about (1) and set up your air conditioning (1) (2) & how to refill your A/C system for $20 (1) (2) (3) (4) & where to find your low pressure aircon recharge port (1) & what refrigerant PAG oil to use (1) (1) & R134a conversion information (1) (2) how to measure A C temperature (1)
