Old 04-17-2013, 08:10 PM
5series92 5series92 is offline
Mein Auto: 540i sport
Auto to manual 6 speed conversion parts list
Hello all. I have decided to convert my 97 540ia to a manual 6 speed gearbox, looking around online I have found discussions but none on the e39 540i I'm just looking for a list of all the parts I would need for this.
So if you have gone through this or have an idea of what parts I need besides the tranny, flywheel, clutch and drive shaft please feel free to comment. Thanks in advance
Old 04-17-2013, 08:25 PM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
Not much off the top of my head
Driveshaft
pedals
cruise control switch
BMW INPA, NCS Expert
transmission and linkage
clutch hydraulics (slave cylinder, master cylinder, hoses)
rear main seal
flywheel
clutch you should replace anyways
Its not too bad if you have a parts car at like a junkyard it can be done cheaply
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 04-17-2013, 08:36 PM
Driveshaft
pedals
rear main seal
flywheel
I found a totaled donor car on Craigslist I just don't know what parts to pulls off it.
Old 04-17-2013, 11:36 PM
Mysemannen Mysemannen is offline
Mein Auto: 540
I would also try to salvage the manual engine harness as it differs from the auto one regarding reverse signal.
Old 04-18-2013, 05:57 PM
hh3uunp's Avatar
Ball Don't lie
I don't want to disagree because I have never done a complete swap but wouldn't it be a lot more easy just to modify the existing harness. When I see all those wires I would faint
Mods
Old 04-18-2013, 07:29 PM
e39 crackr e39 crackr is offline
Mein Auto: '01 540i/6, '98 528i/5
I will be doing my swap Memorial day weekend.
Here's a couple of links to help you out:
http://forums.bimmerforums.com/forum...ght=faq%206spd
http://forums.bimmerforums.com/forum...light=swap%206
http://forums.bimmerforums.com/forum...ed-Swap-Thread
Life is too short to drive fwd cars.
MNe39 on the Facebook!
Old 04-18-2013, 09:03 PM
Originally Posted by e39 crackr View Post
How long do you think the whole process is going to take?
Old 04-18-2013, 10:20 PM
Mein Auto: 540
Indeed, use the salvaged one to compare
Old 04-19-2013, 03:30 AM
With the right tools and people to help, should take 2-3 days at most.
Old 04-19-2013, 07:49 AM
The reprogramming seems to be the most challenging part. I spoke with a BMW indie specialist, he said the ecu always has some bugs and little issues after the reprogram
Old 04-19-2013, 11:04 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
I would say the easiest part is the programming. Retrofitting parts and wiring will be the most challenging. That is, if one knows how to program. It really isin't too challenging to program once you get the hang of it. So learn how to do it yourself or take it to someone how does BMW programming regularly. Your local BMW specialist probably has no clue to what they would need to do. When they swap modules they use tools like Autologic, Progman, DIS etc. where you only need to press few buttons to program a new module or retrofit equipment. When your doing something like this you need to tools like NCS Expert. The difference is that NCS Expert won't give you any guidance like Autologic, Progman, DIS etc. will. The upside is when you know what you want to do in NCS Expert you can do it pretty damn fast.
Old 04-22-2013, 12:57 PM
Reefin' Dude Reefin' Dude is offline
Mein Auto: 02 540it
i am also thinking of doing this swap, though on a touring. maybe the touring is different, but why do you need to swap out the drive shaft? the part numbers are the same. wouldn't the part numbers be different if the lengths were different?
G~
Old 04-22-2013, 01:41 PM
G~
Because the drive shafts have different lengths, i think the manual is a bit longer than an auto
Old 04-22-2013, 01:50 PM
Mein Auto: 02 540it
i did some more searching, the part numbers are different. they do seem to be the same drive shafts for both sedan and touring. i must have looked them up improperly the last time i did this in RealOEM. sorry for the confusion.
G~
Old 04-22-2013, 01:52 PM
Mein Auto: E39 540i
Late reply
Old 06-17-2013, 05:23 PM
tt_tony tt_tony is offline
Mein Auto: 530i
I have two questions:
Is it possible to swap a 5 speed from a 2000 528i into a 2003 530i?
-and-
Since I/we have access to donor cars and relatively cheap parts, why don't I/we just change ALL the necessary modules and electronics instead of worrying about programming and incessant "bugs"?
Thanks,
tony
Old 06-18-2013, 02:36 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
she'll never run again!
cluster
steering wheel
slave cylinder line and master
gibo, drive shaft houseing
drive shaft
trans and mounts
+ all thee electrical problems..... (this is why she'll never run again)
15486372<-----
Old 06-18-2013, 03:53 AM
cluster
steering wheel
drive shaft
trans and mounts
Sounds like you have not found the right shop to do the reprogramming. Mine came out just fine, took 5 flashes but it's all good!
Old 06-18-2013, 05:20 AM
Mein Auto: 530i
ha, first of all, what is a gibo? (gearbox maybe?)
second, all the parts you mentioned are easily changed so, again, why can't I just swap out the electronics as well?
Even if every module in the vehicle is tied together through bus comm, why can't I just swap them all?
thanks
Old 06-18-2013, 05:40 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
A bit late, but I pdf'd the xls sheet for a manual conversion. The list is for a e46, but having the p/n you can easily cross-check for the e39 p/n
ManualConversionPartsList.pdf
Old 06-18-2013, 05:54 AM
Mein Auto: 530i
that's great. thanks for that. so that "total price", did you have a donor car?
Old 06-18-2013, 06:23 AM
Burning2nd's Avatar
Under the lift arms
Lol ok ok,,,, were talking swaps but we don't know what the Gibo is ??? Lol come on
15486372<-----
Old 06-18-2013, 06:25 AM
Burning2nd's Avatar
Under the lift arms
thanks
Show me the money mr ez swap, you swap it and get it running right and then come back and say how great of a swap it was ...
15486372<-----
Old 06-18-2013, 07:55 AM
Mein Auto: 530i
i said the parts are easily swapped. I didn't say it would be easy to get it running. that's what i'm asking about!
btw, i've been working on cars a long time (relatively new to bmw's, i'll admit) and ive never heard anyone heard it called a "gibo". weirdos.
Old 06-18-2013, 09:44 AM
Burning2nd's Avatar
Under the lift arms
Gibo is the flex disk between the trans out put and the front of the drive shaft
I've also been working as a mechanic my hole life , granted I now do industrial maintance (better $)
Bimmers are no different , if your set in a swap first thing u need is all your electrical diagrams your gonna need the Bentley manual
Honestly it's not worth it , sell it and buy a new one
15486372<-----
