Old 04-17-2013, 11:47 PM
musa's Avatar
musa musa is online now
Mein Auto: 528ia , X5 4.4 S, 335i cp
Does installing HID auto leveling hardware need LCM replacement/update?
Hi,
I had updated my '97 528 headlights from halogen to Hella AE HID years ago and all has been well. Now I want to add the auto leveling system that is linked to the suspension. I found the hardware for this for $75 from a salvage yard. My headlights have the auto-level stepper motors at the back.
My question is do I also need to replace the LCM or it just requires a software update? Will the xenon headlights initialize (move up and down) when the ignition is turned on? I see this happening with my X5 which has HID.
Thanks for any pointers.
Old 04-18-2013, 04:00 AM
rdl rdl is offline
Mein Auto: 530i 2003
I can't answer your question directly but these links may help you find the answer.
Xenon retrofit instructions
http://www.gavandkel.co.uk/PDFs/276en.pdf
http://www.gavandkel.co.uk/PDFs/6098EN.pdf
Comprehensive list of retrofit instructions for E39
http://www.gavandkel.co.uk/E39.html
Regards
RDL
Old 04-18-2013, 08:36 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
There are different LCM models within the same year. looking at realoem, you will see LCM s/n for non-xenon and LCM s/n for xenon.
Look here: http://realoem.com/bmw/showparts.do?...20&hg=61&fg=25
Item #2:
Light and check-control module (LCM)
AND:
Light and check-control module (LCM) for vehicles with Xenon lights.
The modules look identical, but I don't think the difference is ONLY coding.
Old 04-18-2013, 09:28 AM
HTK12 HTK12 is offline
Mein Auto: E39 540i
If, I'm not mistaken the xenon LCM got automatic adjustment vs halogens that got manual adjustment. The modules are physically different. LCM for halogen has the electronics for manual adjustment and the LCM for xenon doesn't have those. You should be able to code the current LCM to work with the self-leveling. The retrofit wiring is quite a PITA to do.
