Old 04-16-2013, 07:08 PM
jwanes jwanes is offline
Mein Auto: 2009 750I
rear power outlet fuse location
My right rear power outlet is not working. The dealer wants $75 to diagnose if it is a fuse and replace it. If it is a fuse it is not covered under warranty. So $70 to diagnose and $5 for the fuse. My question is where is the fuse for the right rear power outlet. I searched the forum and could not find any info. on the subject. Thanks in advance.
2009 750i Imperial Blue
Old 04-17-2013, 12:53 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
It should be inside the trunk, under the right hand side trim.
Old 04-18-2013, 07:10 PM
Thanks, I found the fuse box and the chart but it has 4 fuses for power outlets with symbol
- Co--> +
behind the glove compartment
#54 20A
#65 15A
In the trunk
#147 15A
#176 15A
Does anyone know which fuse corresponds to the right rear outlet?
Old 04-19-2013, 03:45 AM
Hope these help. If all else fails, you can either remove them and check them visually or check via a ground lamp while still connected.
Old 04-19-2013, 11:31 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
That sounds harsh to not being covered by warranty. I'd argue that with the Client Advisor politely.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
fuse, power outlet
