E34 (1989 - 1995)
Old 04-08-2013, 12:24 PM
martindaman martindaman is offline
Mein Auto: 1989 BMW 525i M50
BMW 525i E34 Central Lock problem
Hey bimmerfest!
I kinda have a small problem with my e34.. It seems that the central lock doesn't work
It just doesn't do anything when i turn the key, besides locking the door that the key is in.. But if i lock it from the passenger door it also locks the tank/fuel cover this is a bit annoying, I've checked all the fuses (both in the front and under the backseat) and they all look fine, is this a common problem and do any of you know the solution to this ?
The only way to lock/unlock the backdoors is by pushing the pin.
The car is an
1989 Bmw e34 Saloon
M50b25 engine non vanos
It would be great if you would help me out
Best Regards: Martin Mortensen
Old 04-08-2013, 04:02 PM
south26 south26 is offline
Mein Auto: 535i 1989
Sounds like a bad actuator. They are easy to replace, if you were closer I would offer to sell you one.
Andy
Old 04-09-2013, 01:10 AM
Thanks for the reply.. I'll check it out this afternoon!
Old 04-09-2013, 02:00 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
so let me get this straight, it works from the passenger door and the boot/trunk? but not the drivers door? yes will be a worn actuator that sneces where the key is in the door.
mine did the same about 6 weeks ago, was giving me grief so took it all apart, just a connector had fallen off i must not have clipped it up properly
E30 above Sold
Last updated 2nd January 2014
Old 04-09-2013, 02:46 AM
Yep! That's how it is.. It only locks the passenger door and boot/trunk.. Can't unlock the passenger door though. But I'll take the door apart today and see if its just a connector or some like that.
Old 04-11-2013, 10:25 AM
WC5150 WC5150 is offline
South East Area*562*
Mein Auto: 1995 525i
I had the same problem one time, only, not only did the locking system not work, but my car wouldn't start! All I did to fix the problem was I disconnected the battery terminals for 2 seconds and hooked them back up! So I think all I did was reset the system? But it worked!!!
Old 04-19-2013, 12:45 AM
the thing is the car starts probably. but can it be a sensor ? while driving it says my door is open all the time ? Or is this not related..
But im pretty sure it's a connector, or maybe the central lock relay, but then the lock on the right side wouldnt lock the gas cover.
Oh well i got a free central lock relay, trying to switch it today. And look for problems with the connectors.
Thx for the reply's guys!
Old 04-20-2013, 08:00 AM
HipMusic Man HipMusic Man is offline
Mein Auto: '89 535i
WC that was the anti-theft. By doing the reset by battery like that it also reset the anti-theft.
Check the actuators in the doors for the locks. the bracket holding the actuator in my driver side door broke somehow. So unlocking it was a nightmare. If yours are broke you can use zip ties for now making sure they're not in the way of the window brackets moving up and down. Then get a new bracket. They are a pain to install from the looks of them but that's what I would do.
If its not the brackets look at the central locking control module. I believe its under the back seat but im not sure with your car. The manual might have something for that. The door latch button affects the central locking. My 535i has a viper remote start and keyless entry that I installed and I found out a lot of compontents in the car interact with the central locking. Even my sunroof and windows roll up when the doors are locked. thats my favorite feature.
Sent from my SGH-T989 using Bimmer App
Old 04-20-2013, 10:28 AM
Larrick Larrick is offline
Mein Auto: 1994 525it
There is a little known function with the e34 locking system.
It is mentioned in the Owners manual. I actually locked myself inside a 525it in the parking lot
of a "Pick and Pull" in California. It was embarrassing as I had to be aided by AAA wedging open
the door so I could hand the key out to be rescued.
The car would not star either. It is some kind of security locking system.
The Manual warns not to do it with people in the car!
We think that my son inadvertently did something to the passenger side lock while we were loading
our Pick and Pull treasures.
It is just something to think about but I believe you have a bad accuator.
Old 04-20-2013, 02:01 PM
Mein Auto: '89 535i
Werent you able to just unlock it by pulling up on the door lock?
Old 04-20-2013, 03:45 PM
Believe me ..I was locked inside a car. The owner of the tow company came down just to see the moron stuck in his car.
He joked that he should have brought a blonde wig for me to have his picture taken with me. I was the laughing stock of the
tow company. the owner is a well known race car driver in the area.
The first thing the AAA guy asked me was to lift the door lock. They all regarded me as an idiot.
THe mini-jaws of life was needed to get the keys out of the car.
Read the owners manual for details of the locking system if you don't believe me.
Old 04-20-2013, 05:46 PM
Mein Auto: '89 535i
Facinating. Good story though. Lol
