Old 04-21-2013, 04:43 PM
bfv bfv is offline
Mein Auto: Rickshaw
Tire change before lease end Question
I have 32 K miles on the car and 11 months to go on 12K/36 mo lease. I will be extending the current lease for at least 6 months with BMWNA. I want to do second ED in summer so will extend the lease that expires in March 2014 to August 2014.
By that time, the car will have have around 40-42 K miles on it and likely require new tires upon lease return. I wonder if I should change the tires now and use (around 10K miles) a portion of new tires before returning it!!
Need opinion re: approach to this situation. ALSO, Do I have to replace tires with same company or any company with same specs (i.e: all-season, run flats, 17" )
Thanks.
Old 04-21-2013, 05:22 PM
jjsC6 jjsC6 is offline
Mein Auto: See Sig
I had a similar situation on an Infiniti a few years ago. I tried to milk the original tires to the end but didn't make it. I wished I had changed them out earlier. It all depends on how much tread you have left.
GONE: 2012 BMW 550 M-Sport
2016 Audi A7 Prestige
2016 Lexus GX 460---Wife's car
Bikes...2015 BMW 1600 GT---2016 BMW S1000R---2012 Ducati Panigale
Old 04-21-2013, 05:49 PM
rawmn rawmn is offline
Mein Auto: 530i 2001
You can buy used ones from a junk yard or somewhere else way cheaper and return the vehicle to the dealer
Old 04-21-2013, 08:49 PM
Nison's Avatar
Nison Nison is offline
Mein Auto: 2011 535i xdrive
they only have to be run flat with same size
Old 04-21-2013, 09:31 PM
miamiboyca's Avatar
miamiboyca miamiboyca is offline
Mein Auto: F80 6MT
How is the tread currently? If you think it they are adequate for turn in, then get a new set of non-run flats now... and put the run flats back on before you turn it in. You can either sell or reuse the non RFT.
2015 M3 - Mineral White, Sonoma, Exec, LED, Adaptive Suspension, HK, 19" Light Alloy, 6MT ED 7/7/15 - Adrian
2013 535i - Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD - Greg Poland
Old 04-21-2013, 10:13 PM
spadae2 spadae2 is offline
Mein Auto: 2015 750ix
If you are buying a new BMW, run them into the ground if you can. If BMW CPOs your car they will put new tires on it. Also, I have had very good luck with my dealer when buying a new BMW in the same situation, I told them I will buy new run flat junks {they must must have them} on to SELL the car, they buy me a set of non-RFTs for my new car when it arrives. RFTs are the worst. And if you are not getting a new BMW... well do what most dealers do to you...
__
2015 750i X-DRIVE, M-Sport, (born 3/6/2015), Moonstone Metallic, Ivory White/Black w/Honey Walnut, ARS, B&O Sound, Escort 9500ci. VO and FDL Coded. BMS Stage 1.
Old 05-16-2013, 05:03 PM
bfv bfv is offline
Mein Auto: Rickshaw
The tread currently is about 4/32". I plan to drive another 10-12K miles.
Also, will putting non RFT from some company affect warranty in any way?
