Old 09-29-2012, 10:25 PM
MARINE2 MARINE2 is offline
Mein Auto: 2008 535i
check my post
Old 09-30-2012, 10:04 AM
Rebound X3 Rebound X3 is offline
Mein Auto: 2010 528Xi
Originally Posted by Shahul_BMW View Post
Couple of questions on 08 535i with iphone 3gs
1. Why wouldn't all missed/reveived/dialed numbers from my iphone show up in the idrive communications
2. I do no see an option of Messaging/sms in the idrive communications
Please help
1. The only calls that will show up are those calls that occur while your phone is paired with the car.
2. Sorry, can't help here, although I don't see the utility of sms while driving.
Old 10-01-2012, 09:41 PM
Try this step
All,
I found a serious work-around for most phones. Here's the steps.
1) Go to Bluetooth > Settings > pair phone (do not start pairing just yet)
2) Set on your Bluetooth selection in your phone and turn the phone off.
3) Turn your phone back on.
4) With the Voice command (in the newer vehicles) follow these steps:
>Press voice command and say > Bluetooth (it will repeat the command)
>Go down the iDrive menu to >Settings >start pairing
> With your phone >go to Bluetooth settings > pair >enter pin code on phone & iDrive
5) It will tell you that pairing is successful but not display phone information
>Press Voice command and say >Bluetooth
>Go to phone in your iDrive >Go down to your phone in the list and say> A to Z
6) The Voice Command Module will say "Searching for paired phones". If it does not say this then you did something wrong.
7) While searching for the phone it will enable Bluetooth again on its own in about 6 seconds.
8) Now toggle your phone from "MUSIC ONLY >on" to "MUSIC ONLY>off" your phone book will be displayed.
Note: if you already have a phone paired but can't see your listings, jump to step "5".
I hope this wasn't too long. Once you get use to it it'll go faster.
Key Points:
>Clear Paired phones
>Activate blue tooth in your phone then turn cell phone off
>Turn phone back on and use voice commands
>Pair phones> use voice commands> say "Bluetooth">go to phone in iDrive>
>Go down to phone ID> press voice and say> A to Z
>Listen for "Searching for Paired phones"
>Toggle from MUSIC ONLY>on to MUSIC ONLY >off after 6 seconds
Old 10-01-2012, 09:43 PM
Has everyone tried this yet
All,
Key Points:
>Clear Paired phones
Old 10-02-2012, 08:50 PM
Devil dog, the first time was probably enough.
Old 10-26-2012, 03:43 PM
dembones64 dembones64 is offline
Mein Auto: '06 530i
2006 530i
Phone HTC Evo 4G
will pair with car but will NOT import contacts into car. I have to dial manually or dial via voice activation (pain in the ass)!
Old 11-17-2012, 07:11 PM
whdigital whdigital is offline
Mein Auto: 2007 525i
FYI: Samsung Galaxy S3 now imports contacts with 2007 iDrive!
I tried everything, but the definitive fix - for me anyway, was T-Mobile's official update to Jelly Bean (4.1.1) OS. Once update the phone still would not sync. contacts with the iDrive UNTIL I did a factory reset of the phone and then re-paired it to the car and bingo. FWIW, I am a very technical individual and tried EVERYTHING even remotely talked about on the net about this issue.... I have always been able to get the phone to pair OK, but just not transfer contacts; until now. Very happy here!
Old 11-18-2012, 04:20 PM
TRS550 TRS550 is offline
Mein Auto: 2007 550i
Galaxy S3 paired with 2007 550 I drive. Phone book came thru with no issues.
Old 11-18-2012, 07:07 PM
Can you tell us what version of Android you are running? This is something that MANY people have struggled with. Would be nice if we can start tracking the details that work.
Old 11-19-2012, 09:53 AM
astrohip astrohip is offline
Stuart in Houston
Send a message via AIM to astrohip
Mein Auto: 2013 550i
I also have an S3 on a 2007 550. No problems either.
Started on whatever came on the phone, which was the predecessor to ICS. No issues. Then ICS came out, and still works great. Never had a problem, regardless of Android version.
I have a 2013 550 on the way, hopefully just as trouble-free. And also hoping I get Jelly Bean soon (Verizon is a little sloooow on this update, I know Sprint has already pushed it).
Current BMWs
2016 550i Mediterranean Blue, M-Sport--del Nov 2015
2013 X5 5.0 Orion Silver--del Dec 2012
Prior BMWs
2013 550i Space Gray, M-Sport
2009 X5 4.8 White (w/hitch)
2007 550i Monaco Blue, Sport
2004 X5 4.4i
2003 540i M-Sport w/Dinan mods (last of the great E39's)
2002 X5 3.0
2000 540i Sport
1995 525i Sport
1991 325is
1986 325es
Old 11-19-2012, 07:51 PM
It's Ver 4.0. Very simple process.
1. Turned on the phone's Bluetooth via the settings menu.
2. Turned to "Settings/Bluetooth/Pair a new phone" in the I drive menu.
3. When prompted by the phone, I entered a 4 digit password
4. When prompted by I drive to enter the same password, I enetered the same 4 digit password.
5. Phone comes back and states that BMW phone is requesting permission to access contacts list and call registry.
6. Click on "do not show again" and then "accept".
Phone list imports and everything is operational.
The process will not work if you do not click on "do not show again" in step 6. You must do this, then click on "accept"
Give it a try.
Old 11-25-2012, 05:03 PM
zufahren zufahren is offline
Mein Auto: 2013 X5 35i
Samsung Galaxy S3 - 2008 528i - paired immediately, all contacts sync'd, work great
Old 12-01-2012, 02:37 PM
BMW 535 BMW 535 is offline
Mein Auto: BMW
Samsung Galaxy III
BMW & Samsung Galaxy III
Just found this forum about BMWs. I finally bought my BMW last year, started looking at the 335 but ended up buying a 2010 535xi. My question is (and sorry if already asked in here, learning how to navigate this site) I am about to change cell phones and thinking about getting the new Samsung Galaxy III. Has anyone paired this phone with their bmw and been able to display texts and emails and of course names & phone numbers?
if not, what new phones can be paired that will show emails, texts and phones?
thanks
Just saw zufahren answer, did you also get text and emails to work with the idrive?
Old 12-01-2012, 03:53 PM
Hi BMW_535 - see the previous post - S III pairs fine. As far as I know you cannot display SMS or email with any phone, wouldn't exactly be safe driving practice!
Old 12-01-2012, 08:54 PM
Mein Auto: BMW
Hi zufahren,
thanks for replying. As far as I know it is possible to display both sms & email but will not be able to work it while the car is moving. I found it out here: that is why I am wondering if the new Galaxy SIII can be used for this. I know it has to do with some blutooth-MAP protocol but obviously I am not that savvy on this and hopefully I can find out so Ill know what phone to update to.
Old 01-10-2013, 12:51 PM
Ybrand Ybrand is offline
Mein Auto: X3
What about text messages. Do you have those paired?
Old 01-15-2013, 09:34 PM
Darnell J Moore Darnell J Moore is offline
Mein Auto: 545I
I have a 2005 545I. My first phone was the Motorola Razer, which worked very well. I now have a windows phone and it works, although not as well as the Razer.X] ability to make/receive calls
[X] phone book automatically synches to car
[X] dial by name (without verbal training of system)
[X] calling name display (using adddress book)
[X] ability to send/receive SMS
Old 02-13-2013, 08:07 PM
Billd104's Avatar
Billd104 Billd104 is offline
Mein Auto: 2015 Mazda 6 GT
Phone model: HTC One X on AT&T
Car model: 2007 530xiT
[X] ability to make/receive calls
[ ] ability to send/receive SMS
2007 530xiT -- Titanium Silver / Black Dakota / Nav / PP / Step / Sirius / HD / CWP / CA /Rear shades / 2 Diono Monterey Booster Seats in Pink :>) / Hüper Optik tint -- Ordered 08/19/06 -- Delivered 10/17/06 -- 59 days order to delivery.
"Money is a strange business. People who haven't got it aim at it strongly. People who have it are full of troubles." -- Ayrton Senna
BMW CCA Member
Old 02-18-2013, 09:57 PM
chinesestunna chinesestunna is offline
Mein Auto: Acura TL
Phone model: Galaxy Nexus on VZ running AOKP JB
Car model: 2005 545i
Old 03-06-2013, 10:56 AM
Zkanaan Zkanaan is offline
zeyad
Mein Auto: 2006 530xi
E60 bluetooth issue
I have 06 530xi and the bluetooth in my car is not pairing anymore with my cellphone the galaxy s3 and its giving me code cu20240, before it was working good. Thank u
Old 03-06-2013, 12:04 PM
njlou njlou is offline
Mein Auto: corvette/528xi
I had a similar problem with a different unit.
The SA told me that the phone was not compatible, even after it had worked well for months. BUT it was at the same time I had trouble with the car battery. Then I re-paired and it worked fine for YEARS!
All this is too complex for mere mortals.
Old 04-11-2013, 05:46 AM
zaxxon007 zaxxon007 is offline
Mein Auto: BMW E60 530D
Samsung Galaxy S I works perfectly including phone book.
Old 04-18-2013, 08:25 PM
otisdawhino otisdawhino is offline
OtisDaWhino
Mein Auto: 2008 BMW 535i
Will the iPhone 5 work on the 2004s ??
Old 04-18-2013, 11:06 PM
I think it is important that you have latest firmware and latest TCU. As I've installed second hand TCU it supports new devices.
Old 04-22-2013, 08:54 AM
limeykraut limeykraut is offline
Mein Auto: 2006 530xiWagon
iPhone 5 issue
Originally Posted by mike535xi View Post
All iphones work with this car. It took me days to figure out why my iphone 4 wouldn't pair - I kept hitting the 'back' arrow on iDrive instead of 'CONFIRM PASSKEY.' If you're having a problem with the car pairing with an iphone 3G, GS, or 4 (I troubleshot with all - and all now work) try scrolling down and actually entering the passkey. I am so frustrated at my ineptitude. Good luck.
Newbie here, we got my wife's old phone to pair, surprisingly, but my iPhone 5 wouldn't. I entered the passkey, then pushed iDrive controller 'up' to the 'return' key, and got a fail mesasge. Is that what I'm doing wrong?
'06 530xi
Similar Threads
Which bluetooth BMW 7/5 series compatible phones work in Europe? neurom European Delivery 22 04-02-2005 02:15 PM
are Chinese language cell phones compatible with BMW bluetooth?? alsu1983 3 Series & 4 Series 1 01-15-2005 03:45 PM
BMW Update for S54 Engines BMWNA 1M & M2 2 08-13-2003 06:55 PM
