F02's on lowering springs, please check in... - Bimmerfest - BMW Forums
Old 03-26-2013, 09:59 AM
Tb750 Tb750 is offline
Mein Auto: 750li
As far as I know only h&r has springs for our cars?
Please post pix of any lowered f02's on these springs. Trying to see if they kill the gap.
Old 03-26-2013, 12:15 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Originally Posted by tb750 View Post
as far as i know only h&r has springs for our cars?
ID:	368328 Click image for larger version
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-26-2013, 01:01 PM
swb3's Avatar
swb3 swb3 is offline
SWB3
Mein Auto: 2014 i8 and some others
I will be checking tomorrow and post what I learn if different than this
2014 i8
Old 03-26-2013, 10:38 PM
Mein Auto: 750li
Originally Posted by haastx10 View Post
From what I can recall the X drives sit a lot higher than non? Hence would just the Li go lower? I want to kill the gap
Do you have a before and after?
Old 03-26-2013, 11:01 PM
RocknDoc
The H&R website shows 1.4" drop in front and 1.3" drop in rear for a 760Li... exactly the same as my 750Lix...
Here are some before and after pics shot by my mechanic... not the best but you get the idea. From what I've seen on this site, if you completely want to eliminate the gap you have to lower and upgrade to 22" rims but be careful with the offset as they might rub!
Before
After
Old 03-27-2013, 12:31 AM
Mein Auto: 750li
Before
Attachment 368487
After
Attachment 368486
Sweet thank you, looks good! Much better, actually from those pictures I think the HR drop is perfect. I will be doing some custom offset 22s for sure. I want to run 22x11 in the rear with a 6" lip like the old 7 series but looks like not many people have had success
Old 03-27-2013, 01:15 AM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
You are right; the X drives are much higher than the rear wheel versions. These aren't good pics, but show the difference on the stock 19" 235 wheels
ID:	368514   Click image for larger version
Old 03-27-2013, 06:22 PM
swb3's Avatar
SWB3
Did you use the H and R drop of 1.3 and 1.4 inches?
2014 i8
Old 03-27-2013, 10:08 PM
Yes. Just the standard springs from H&R. As mentioned in other posts, the long version has just the lowering links in the rear (cheap plastic) and the springs in front.
Are you in Mpls? If so, Imola in Golden Valley does a nice job dropping the car...
Old 03-28-2013, 04:21 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
H&R Super Sport will kill almost all gap and will still clear a 22"
Old 03-28-2013, 04:41 PM
swb3's Avatar
SWB3
Yes I am and I was just given a card for their business last week, thanks for the recommendation I will check them out.
2014 i8
Old 04-15-2013, 04:28 PM
Mein Auto: 750li
Will those work on the li?
Old 04-17-2013, 02:36 PM
sanhonda22's Avatar
Sleek Sam
I need to check the PN, but I think they will.
Old 04-18-2013, 12:51 AM
Mein Auto: 750li
Please let me know brotha, I want to order asap. I think only difference is that the F01 versions have 4 springs, and Li verions have the 2 springs and rear links?
I dont care if I get 4 springs, I can get my local guy to hook me up with links... I just want to make sure the front springs will fit. At the same time I dont want the front to be ghetto low lol. Just enough that it should kill the gap, but not cause driveability issues/ clearing 22s on full cut turns etc...
Your thoughts please
Old 04-18-2013, 02:56 PM
sanhonda22's Avatar
Sleek Sam
I know with the E65/E66, fronts are the same. I wouldnt see why the fronts wouldnt be the same on F01? Maybe you might want to go to realoem.com to compare the part numbers on F01 i vs li and see if the front has the same springs - struts. If the struts are the same PN, it should be interchangeable.
Here are pics of 1 on H&R super sport with 22"
ID:	372024   Click image for larger version
Old 04-18-2013, 03:43 PM
Mein Auto: 750li
Oh that's sits perfect! I checked real oem and they don't list any part numbers says to contract dealership or something...
You wouldn't happen to have any pics of a lowered f02?
Old 04-18-2013, 05:21 PM
swb3's Avatar
SWB3
I went through the dealer and they offered me H & R and HAMANN for my F02. I am taking it in Monday for the install and should have it Tuesday or Wednesday and will post up pics. I went with HAMANN because it is a progressive spring, lowers same as the H & R about 1.4". I have air suspension so they only install the fronts and rear adjusts to same.
2014 i8
Old 04-18-2013, 08:08 PM
sanhonda22's Avatar
Sleek Sam
Sorry, no pics. Out of all that I have done, I only took pics of the one I posted and a SWB B7.
Old 04-19-2013, 07:05 PM
Mein Auto: 750li
Any better pics?
Old 04-19-2013, 07:27 PM
Any better pics?
I will take some over the weekend. We just had another 12" of snow . So tired of cold winter weather in spring...
Old 04-19-2013, 10:15 PM
Mein Auto: 750li
Thanks!
I hear ya, cept it's pissin rain out here!
Old 04-21-2013, 01:27 PM
Thanks!
Here we go. This is an X-drive with 19" stock wheels, a 1.3 & 1.4" drop. The gap between the top of the tire and the wheel arch is about a finger and a half.
It will look more aggressive with larger wheels and lower profile tires obviously, but I wouldn't want to go lower than that.
ID:	372509   Click image for larger version
Old 04-21-2013, 07:53 PM
Mein Auto: 750li
Sweet, thank you! Sits nice, going to order sports springs and believe on the non xdrive will sit lower
Old 04-22-2013, 11:31 AM
Snorlax Snorlax is offline
Mein Auto: _
Got a quote for mine to lower with H&R springs. $350 labor and $300 for springs that I bought on my own. $650 out the door if I choose to go with it. That is here in San Diego.
Old 04-24-2013, 09:15 AM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
That is a SUPERB deal! Especially out there in high a$$ Cali! Run do not walk...
~ Big Marcus
