Old 04-21-2013, 05:20 AM
sorbet35 sorbet35 is offline
Mein Auto: corvette,landrover
opinions please
Hello all,
Today i will be looking at @ 05 X3 with 78 k miles.Owner tells me its in great shape with a good service history.Besides the regular used car inspection which i will be doing is there anything specific i need to look out for and do you think its a good $.
THANKYOU
Old 04-21-2013, 06:28 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
How much is he asking? Since this sounds like a private party sale, you can get a full history (up at least to 50K miles) from your local BMW service center. They will probably not give you a print out but in virtually every case will sit down with you and go over what has been done, any repairs, and (important!) any continual reflashes of the transmission. The reason they are so helpful is that they want you as a new customer! Be sure to read the transmission sticky at the top of the page.
Old 04-21-2013, 09:38 AM
Mein Auto: 2004 X3 2.5i
It's an '05 so A/T sticky doesn't apply.
This is where we usually advise to especially look at:
- operation of panoramic roof
- window operation
- evidence of rain leaks
- fluid leaks (struts, diff., VCG, OFHG, etc.)
- noises from transfer case (ask for evidence that fluid has been changed)
Ask private seller if they are a member of an owner forum like Bimmerfest.
If they are, that tells you they know quite a bit about the X3 and how to treat it right!
Old 04-21-2013, 10:34 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
+1 to the above from Supercourse.
I'd also add looking for broken rear coil springs and checking the air conditioning to that list
Old 04-21-2013, 12:34 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
agreed, that mileage is when the following start to go south
CCV
VCG
OFHG
intake tube
belt tensioner/belt
front forward control arm bushings (tension struts)
auto tranny oil change
X drive fluid change
and around 100k miles you should look at a cooling system overhaul.
Old 04-21-2013, 05:23 PM
thanks for the reply, i forgot to add he is asking $10,500
Old 04-22-2013, 08:03 AM
Super - my bad, I missed that it was an '05.
Old 04-22-2013, 10:48 AM
mlukas161's Avatar
IMO that's a good price considering the mileage and the year!
If the previous owner has maintenance records it may be a good deal.
These vehicles are very easy to work on if you have the right tools.
Old 04-22-2013, 11:56 AM
sjladopoulos sjladopoulos is offline
MotorPress.ca
Mein Auto: 2007 BMW X3 3.0si
Is it a 2.5i or 3.0i?
If it is a 3.0i with lots of extras (premium pack etc) it sounds like a bargain.
If its a base 2.5i, then its normal asking price, no special deal.
Make sure you check what previous guys said and you are good to go.
FYI: I bought my 07 with 90k miles. BMWs never die with proper maintenance
Old 04-22-2013, 06:34 PM
even a 2.5 is a good price if it has the premium package (auto climate control, etc)
