Old 04-20-2013, 07:23 PM
rcbloom2 rcbloom2 is offline
Mein Auto: E32 750il, E34 525i
E32 750il Question - Door Locks
The battery went dead in my car. The door locks are electric. I insert the key and nothing happens. How do I get the doors unlocked? WTF?
Old 04-20-2013, 07:25 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
turn key 90 degrees counterclockwise passander side see if that works
Sent from my Nexus 7 using Bimmer App
Old 04-20-2013, 07:52 PM
Gave it a try. No luck.
Old 04-20-2013, 11:50 PM
First740il First740il is offline
Mein Auto: 740il
You need a 750 forum
Sent from my DROID RAZR HD using Bimmer App
Old 04-20-2013, 11:52 PM
So the locks are different on a 750?
Old 04-21-2013, 12:25 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Try by slightly lifting the drivers door handle then turn the key to unlock the drivers door, This always worked on e34 5 series.
Old 04-21-2013, 12:36 PM
I will give it a try. Thank you Peter.
Old 04-21-2013, 01:11 PM
It worked, thank you.
Old 04-22-2013, 12:32 PM
Door lock
Thank you for your kind reply, This was a major issue on e34 models, Peter
Old 04-23-2013, 08:12 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
No, its not that the locks are different on the 750 vs the 740 or any other e38...the difference is in the generation of 7 series...e32 versus e38. You posted your question on the wrong 7 series forum. The e32 7series was built between 1988-1994. The e38 7 series was built between 1995-2001.
For any e38 owners reading this...Peter N is correct in that the e32/e34/e36 requires that the door handle be lifted while turning the key in the lock cylinder counter-clockwise. This lifting of the door handle is NOT required on the e38/e39/e46/e53. Totally different design between the old e32 door locks and the e38 door locks.
e38/e39/e46 - from owners manual
e32/e34/e36 - from owners manual
Q {BMW CCA Member #191509}
(SOLD)
