Old 04-24-2013, 05:19 AM
jjzfitness jjzfitness is offline
Mein Auto: 2000 740i
all kinds of issues
1.. smoke at start up blue but runs grreat???? was told to replace the pcv???
2. oil leaks all over bottom of car- added stop leak and dye- - seems ok for now but the rear main seal still leaking? any suggestions???
3. tensioner or alter noise up front??? how can i test which one it is?
4. rasdio cut off as well as the turn signal indicators on dash??? ignition switch ive been told so im doing that today.....
all off my 2000 740i e38 4.4l
Old 04-24-2013, 11:46 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Smoke at start is most likly your CCV(PVC on other cars, CCV on BMW's). Pull your dip stick with car running and see if you have a lot of suction. If you do then yes, replace CCV.
Rear main seal....yeah, your gonna have to pull the tranny or motor to replace.
For the noise, I would sugeest getting a car stethoscope from a parts store to help isolate your noise. Most likly a tensioner pulley but you never know.
Ignition switch sounds about right for your other issue.
Hope this helps and good luck.
Old 04-25-2013, 04:47 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
for the noise, you could always remove the belts that run through the alternator, start the car up and see if it still makes it. If so, then consider the pulleys, tensioners, belts, etc. Can also do the same for the power steering belts.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 04-25-2013, 09:04 PM
aom7
The same belt runs the water pump, alt, power steering and has 2 tensioner pulleys also. If you take the belt off then your not going to be able to hear whats making the noise.
Maybe I mis-understood what your saying.
Old 04-25-2013, 11:04 PM
aom aom is offline
Moderator
I need to take a look, but you might be right, it's been a few months since I've been in there (great, just jinxed myself!) HAHA. So were there 2 or 3 belts on the E38... one runs the AC compressor and goes through some pulleys, then the other ones do the alternator, pulleys and you're saying the WP and P/S as well?
Old 04-26-2013, 12:32 AM
aom7
You are correct in that statment. There are only 2 belts. 1 runs ac, and the other runs everything else.
Cheers
Old 04-26-2013, 12:48 AM
aom aom is offline
Moderator
Originally Posted by JasonSC540ia View Post
aom7
Cheers
ah very good. I would only remove either belt then to help isolate which of the two drive belt componets it could be coming from. I had a low Hz vibration coming from the front, but couldn't tell what from, so by removing the belts I figured out it was a p/s pump that was on its last legs. But if one already knows it's coming from one of the belts' components, then the steth. might be the way to go. My noise was too low and at too varied of an rpm that I couldnt use one, but in the OPs case, might be best.
Then again, if he ends up replacing one pulley/tensioner, I'd just do them all if they haven't been.
