Old 04-24-2013, 03:00 PM
BMW Dark Serb BMW Dark Serb is offline
Mein Auto: 2000 BMW 740iL
2000 740il mysterious oil leak
On my 2000 740il I noticed a small amount of oil on the ground (about the size of a quarter). After looking under the car it looked like it was leaking near the bell housing but the area was mostly dry. I havent seen any oil on the ground for like 3 weeks than yesterday another spot on the ground. What could this be? I figured an oil leak would be something constant not once every several weeks.
Old 04-25-2013, 05:50 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Bell housing huh? Maybe could be a leak from the back of the top part of the engine (read: valve cover gaskets), then dripping down on top of the bell housing, then down towards the bottom of the bell housing. With the car cold, run your hands around the back and sides of the engine, where the valve cover meets the block and see if it's wet with oil. Though if there's that much, you'd usually expect to see a little white smoke and smell it too. But you never know. GL!
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 04-25-2013, 08:02 PM
Thank you very much! I'll do exactly what you suggested I should do.
Old 08-06-2014, 12:11 PM
Mike Robinson Mike Robinson is offline
Mein Auto: 1995 740IL
1995 BMW 740IL mysterious oil leak in the back end passenger side seen after parked
I have this oil leak from the back right passenger side of the vehicle. What is this? Could it be power steering draining. As I just added a quart of power steering a week ago upon hearing the grunting from the movement to steer. Is that what's leaking? Someone give a guy some help.
Old 08-06-2014, 06:54 PM
sealbeach740 sealbeach740 is online now
Mein Auto: 2000 740iS, 2003 540iS
Power steering hoses are notorious for leaking on our cars.
If it were my car, I'd clean the PS hoses, then watch & see how bad they are leaking.
The PS canister top also has a small hole on one of the spoke edges where PS fluid can also leak out if it's filled to high. Also, check the rubber o-ring is not pinched or missing from the PS canister top (it is supposed to sit in a groove you should be able to see in the threads of the top.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
