Old 04-20-2013, 12:25 PM
HneDog HneDog is offline
Mein Auto: 1998 740il & 2010 750li
98 740il e38 sway bar help
So im working on making my e38 a fun weekend car but i have a few issues. there is a lot of body sway and yes i know its a massive car but my sway bar just broke( rusted through) and im thinking if i get a better one could i reduce some of that without spending money on coilovers or springs?
im lookin to do the 6 speed swap later on after i fix up the suspension a bit. and the engine will last a lot longer its only got 50k miles on it and the chassis has 130k but i keep it in the garage and do a lot of rust work/ rust protection.
but main issue is sway bar should i look into after market parts or is there not much of a difference for the OEM part and anyone know how to put that in?
Old 04-24-2013, 06:53 PM
Bigrobsbmw Bigrobsbmw is offline
Mein Auto: 2004 745i, 2001 740i
Sway bar
I did a little research and found nothing after market for our cars. Since you have an il you are ahead of the game because you have a rear sway bar to begin with. The short model doesnt, not even the sport model much to my dismay and suprise. You might be able to upgrade if you go to the Sport model front sway bar, I think its bigger. Replace the rear and be happy to have one at all. A new one with new bushings and links should twist less than an old rusty one anyway.
Old 04-24-2013, 08:19 PM
Mein Auto: 1999 740i
Most car manufactures put a bigger sway bar on heavier models. Since the 750 has a V-12 you might do some resreach to see if that sway bar is thicker.
Old 07-15-2013, 12:59 AM
hmm gettin a sway bar out of a 750 is something that never crossed my mind...thanks guys ill try it out and see how it goes
Old 07-15-2013, 08:37 AM
Look up the part number for the 740 sawy bar and see if its the same number as the 750. If it is'nt chances are its bigger.
Old 07-16-2013, 11:18 AM
rabies rabies is offline
97 740i
Mein Auto: 97 740i
if your car didnt come with a rear sway bar, you most likely dont have the endlink brackets on teh control arms. easy fixt though. drill and tap a hole for bolts for a bracket or weld brackets on.
this is somethign il do this year sometime too.
Old 07-16-2013, 06:48 PM
yea its got the rear sway bar but the front one rusted through and snapped but i ordered a new swaybar, bushings, and control links. that will be taken care of, now anyone know about lowering spring? im lookin to get some H&Rs to drop about 1.5 both ways (still researching parts and ride heights) but can i just put them on without wrecking anything?
Old 07-17-2013, 08:24 AM
97 740i
Mein Auto: 97 740i
theres alot of threads on it. search "lowerd e38" or "slammed e38" seems like eibach has the lowest. springs are around $215-300 for a full set. buy new struts and shocks while your at it. thats what im going to do when i have more $.
Old 03-12-2014, 11:30 AM
its been a while since i last posted here because ive had a different car to drive. The previous sway bar and links i ordered were out of stock and i somehwat put that problem to the side. Im looking to buy one off ebay for cheap and was wondering if anyone knew the size of the sway bar or a part number for it. I can pick up a used pair for cheap on ebay but dont want to buy it unless it will for sure fit. if anyone know the part number or how to find it that would be great because i just cant find a clear solution. also i am wondering if it could put a sway bar from a 2000 740il sway bar and door on my 1998 740il.
Old 03-12-2014, 03:09 PM
jmorgenson jmorgenson is offline
Mein Auto: 1998 BMW 740iL
Look at realoem.com to see if part numbers match up.
Old 03-12-2014, 05:00 PM
^thanks this website is going to help me out a lot with this project.
Old 03-17-2014, 03:49 PM
I found a good replacement but i cannot find any instructions for a sway bar install on a e38. i did find an e46 and e36 video and for those its as simple as connect to the end links and then bolt the bushings to their mounting points but does anyone know if that is the case for a 7er?
Id love to go look under my car now but I am currently at college and am planning to put the part in when i get home.
1998 bmw 740il(current project) , 2010 bmw 750li
Old 08-13-2014, 02:57 PM
update on the car with another question
ive replaced all 4 rusted doors and replaced both damaged bumpers and put a new trunk lid on, 2 clean fenders, 2001 HID headlamps and 2001 tail lights, and fixed up my electronic issues. All I have left to do is fix my brake lines (one is kinked), put on the side skirts, change the spark plugs /coils/boots (misfire codes p0305 and p0308), install the H&R stage 2 springs, and then the sway bar reinstalled to the front end. the sway bar is bothersome to get at because the front sub frame, which has a motor mount on it. My mechanic says he could do the job but would cost a lot in labor. ive searched the web for months and cant seem to find a thread on how to either install the front sway bar or drop the sub frame. I dont quite remember what the sub frame connects too besides that motor mount and was wondering if anyone knows if i could just release the back side of the frame while supporting the engine with a hoist and slide the bar in or if someone knows if the sub frame connects to control arms or anything besides the engine mount.
Old 10-12-2014, 10:06 AM
PasakBoy PasakBoy is offline
Mein Auto: 2002 Z3; 2001 740i
My '01 740i Sport did not have rear sway bar, just a thicker 22mm front sway bar from factory. Over the years, I accepted the fact that BMW knows best and I tolerated the dismal cornering and handling of this big sedan, since I also own a Z3 roadster for sporty spirited driving.
Last year, I decided to install a 15mm rear sway bar. It took a lot of research for this retrofit project. The sway bar came off a 2001 540 sports wagon. I purchased OEM end links, and aftermarket bushings and brackets from Energy Suspension. Then, some fabrication from a local muffler shop, welding the brackets onto my rear suspension arms.
The whole project took a lot of my time for research, but the total cost was $299 for parts and labor. All I can say, what a difference in handling!
Old 12-15-2014, 04:53 AM
Could you possibly post pictures of where you had the mounts and brackets welded onto the car? Im currently tearing apart my suspension to replace control arms and front swaybar upgrade but am seriously interested in doing a rear swaybar project on the car in the near future.
HTML code is Off
