Old 04-19-2013, 05:13 AM
ncord ncord is offline
Mein Auto: 2006 X3
Misfire 06 X3 3.0
I have same problem with shuddering (misfire) when engine under load @ 3000 rpm.
There was oil in plug #2 so I replaced VCG & plug gasket .new plugs, 2-pre cat.O2 sensors,&
new coil pack in cyl.with oil leak.
I STILL HAVE THE DAMN MISFIRE WHEN I BOOT IT... What Next???
PS; I have never had a Check Engine light . 88K miles
Old 04-24-2013, 12:16 PM
Mein Auto: 2006 X3
Anymore ideas out there????
Old 04-24-2013, 07:26 PM
Mein Auto: 2004 X3 2.5i
CEL bulb definitely O.K. - displays with ignition position II?
Worth checking for codes (stored or live) with a scan tool anyway?
Possible that oil in plug #2 didn't mean that definitely was the misfiring one?
(Distinction between VCG leak causing oil in spark plug hole and fouled plug tip?)
Any way to boot it a bit harder to see if that forces a CEL? (Unlikely)
Try some Techron or GM/BMW advanced fuel system treatment on off-chance that one or more injectors need some cleaning?
That's all I've got.
Old 04-25-2013, 04:49 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
How are the RPMs when its sitting idle?
Old 04-25-2013, 11:36 AM
Mein Auto: 2006 X3
Car idles good @ approx.800 rpm.I just checked the other coil pacs and there all reading0.8 on my amp meter.Car starts and runs great until I kick it back going up a hill or merge onto a highway. I can`t find Techron up here in Canada,but I use fuel injector cleaner about every 2nd fill up.
Old 05-19-2013, 03:12 AM
Mein Auto: 2006 X3
Tried switching coil pac from cyl.#1 thru 6.Misfire still happens under load at approx.3000rpm.
What`s left to try????
Old 05-19-2013, 05:55 AM
bdunn bdunn is offline
Mein Auto: 2005 X3 2.5i
Had a very similar situation about a month ago, changed plugs, air filter and problem continued. Then took it to my mechanic who couldn't repeat the misfire. Only code was misfire cylinder 2. Turned out to be a bad tank of fuel, drove me nuts.
Old 09-08-2016, 05:23 AM
Bmwx306 Bmwx306 is offline
Mein Auto: 2006 BMW X3
So you replaced ur tank and problem solved?
