Decarbonization???? - Bimmerfest - BMW Forums
Old 04-24-2013, 09:33 PM
Danny Wolfe Danny Wolfe is offline
Mein Auto: 2001 740i
Exclamation Decarbonization????
I've had a rough idle for a long time now...i ran BG44k thru the injection system and also two cans thru the gas tank....car has new plugs, fuel filter, air cleaner, and sometimes runs smooth but at idle and at first take off the car shudders MILDLY...and intermittently....suggestions? I was wondering if i needed to go the de carbon using water mist thru the intake....anyone done this? IF SO PLEASE TELL ME HOW TO DO IT and what your results were.....THANKS!!!!
Old 04-25-2013, 04:45 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
how are your throttle body gaskets, MAF, emissions hoses? Seems like it might not be carbon issue (kind of rare on these) and more like a vacuum issue? I'd guess.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 04-25-2013, 08:04 PM
i sprayed cleaner CNC i think it is around the intake, and throttle body as well as the OSV and found nothing. I cannot find a vacum leak at all. I also sprayed the tube from MAF to the throttle body and the tube to the air cleaner, found no leaks or change in engine speed.
Old 04-25-2013, 08:08 PM
aom aom is offline
Moderator
how's your MAF, when was it last replaced and how many miles to you have now?
Old 04-26-2013, 09:52 PM
my car has 189k miles. The maf was replaced at 138K. THANKS!
Old 04-27-2013, 12:49 AM
aom aom is offline
Moderator
Hmm, interesting. Do you have access to a DIS or INPA? It might be interesting to see, when the car does do this, what the "Smooth Values" are for each cylinder. Kind of like... OK, this morning it's idling roughly and look, INPA says cylinder 5 is waaaay off, then after a few minutes, it's back to normal again and engine is smooth. Then you could start testing with that knowledge. But, let's say all values are just fine for all 8 cylinders, even w/ the rough idling, then we know it might be something post or pre cylinder... Like OSV or Cats. Just wild guess
HTML code is Off
