Old 04-25-2013, 03:55 PM
PolkNole's Avatar
PolkNole PolkNole is offline
Mein Auto: 2008 535i
2 Weeks Before Maintenance Warranty Expires...
What should I make sure to update? My car shows 3000 miles to its next oil change. Will I get a new oil change or do I need to take a road trip?
I know to get new wipers. What else??
JB4 Tuner; RPi Exhaust; Sport, Prem & CW Pkgs; Nav; HUD; L7; hardwired V1; M Trunk Lip; Chrome Rims; 17% Tint; Michelin PS PS2s
Old 04-25-2013, 03:57 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
No, they will not change the oil until it's less than 1k miles before it's required. However, if the brakes, belts, wipers, brake fluid, anything else covered, get it done. In the last week before my maintenance was up I had them do all that's listed there and they did it happily.
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-25-2013, 04:16 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
I would go nuts. Have them check valve cover gasket, water pump, turbos. bushings, all the stuff that eventually need an overhaul from 60-100k.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 04-25-2013, 04:43 PM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Indy shop can take care of it, i had 10K showing on my car but i did the complete Oil change/filters before i installed the cobb.. Talk to them and they should take care of it with your warranty guys..(Assuming its not CPO)
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 04-25-2013, 05:23 PM
bimmerstien bimmerstien is offline
Mein Auto: 528xi, w/Spt, Nav, PP, CW
I did`t know you can have the dealer do all of those things if it wasn't`t showing that it needed to be done.
Old 04-25-2013, 05:28 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
The 535i is due spark plugs at 45K, and it is not on CBS, and a dealer will charge close to five hundred. So, if you are close, have them do it.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 04-25-2013, 06:42 PM
H F H F is offline
Mein Auto: 2005 545i
Just say u have oil on ur garage floor and can't tell where it's coming from. I did that and got new trany pan And fluid change , also the front timing covers done,, when my warranty expired .
Old 04-25-2013, 06:47 PM
Kamdog's Avatar
<- Bailey
Some dealerships look at customer complains as a way to get BMW to pay for stuff, others don't. I read here to complain about my front brakes squeeking. I did, and I got new pads up front. No complaint would be no reason to check, and since they gad half the job done anyway, they put it on the service plan.
Old 04-25-2013, 07:10 PM
535kjp 535kjp is offline
Mein Auto: 2011 535i XDrive
How positive are you on this? I just recently hit 45K on Sunday
Old 04-25-2013, 07:25 PM
Wagons_Rock Wagons_Rock is offline
Mein Auto: 535xit
100% certain about plugs: its in owners manual, and if you hit milage target its covered
Old 04-25-2013, 07:47 PM
redhotdave redhotdave is offline
Drive as much as you can, take the long way to everywhere. Get within 1k of 45k and make them change your plugs and do what oceans recommends.
At the end of my maintenance thing, I had just below 45k, SA tried to tell me plugs weren't due, I pressed it and they backed down, make sure they give u your old plugs back. I didn't, a coupe months agouti water pump went bad, Indy changed the plugs cause they got fouled from that, showed me the old plugs and said there is no way the dealer changed the plugs back in October, 3 flat spots on the tip that couldn't have happened in just 3-4 months time.
Get as much as you for "free" as you can, once its over its over.
Old 04-25-2013, 07:55 PM
Kamdog's Avatar
<- Bailey
BUT, if you don't say anything, they might not. There is no CBS message that pops up.
See, your subscription to Bimmerfest has already paid for itself.
Old 04-26-2013, 05:47 AM
Oceans10's Avatar
Remember that the dealership gets compensated by BMW NA for warranty and covered maintenance work. So they have an incentive as well. They just need sufficient evidence to carry out the repair.
Old 04-26-2013, 06:18 AM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
My spark plugs were changed by the dealer at 40k miles as normal scheduled service without me having to ask.
Old 04-26-2013, 06:20 AM
Maybe you should get the car inspected by an indy and take the list and pictures to the dealer.
Old 04-26-2013, 10:40 AM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
This is not true. The dealership can do an Maintenance Oil change when the car is in within the 3k mileage of the change. I have had this done 2-3 times on multiple cars(545/550/X5) on both Oil and brakes. This was done in conjunction with my car being in for other reasons but my SA did say that they can and would do it. It will show up as an available service when they read the key but the car will not alert you until you are at 1k. You will have to ask for the Oil change, the dealer will not just do it.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 04-26-2013, 11:35 AM
You might have a better relationship with your SA than I did, at 3 different dealers here in SoCal they all told me they cannot change oil until it's within 1k miles before required according to iDrive. They did say there was more leeway for other things like brake fluid, pads, belts, wiper blades, etc. Although belts and wiper blades do not throw an iDrive warning, they said it's based on the last time they were changed under warranty.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 04-26-2013, 01:38 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
One of which must have been BMW of San Diego.
Horrible dealership, just horrible.
Old 04-26-2013, 01:45 PM
Kamdog's Avatar
<- Bailey
My dealership was much more willing to work with me.
As I said, some are, and some aren't. While I think the dealership gets a nice chunk of change when BMWNA picks up the cost of service, the SA compensation might not be the same, and, I bet ya dollars to donuts, that what they can charge us for a service is more than what BMWNA reimburses them for it.
Old 04-26-2013, 03:38 PM
LOL, nope, in order of crappy service they were: Irvine BMW, Monrovia BMW, and McKenna BMW. Crevier always works with me, gotta love the SA's there
Crevier also had no problem with modded cars, most they ever told me was "nice car".
2008 550i (R.I.P.)
2006 Jeep SRT-8
