E30 (1982 - 1993)
Old 04-19-2013, 01:59 PM
MR2NoVA MR2NoVA is offline
Mein Auto: MR2
Identify this for me
Anyone know what this is? Doesn't look like it's in good shape and I'd like to replace it:
1988 m20 325is:
zoomed out:
Old 04-19-2013, 03:03 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Are you talking about the thing the sensors are screwed into, or the sensors themselves?
The thing they are screwed into is the thermostat housing. The sensors are the engine coolant temperature sensor (tells the ECU what temp the coolant is) and the coolant temp sensor (feeds the temp gauge in the instrument cluster).
http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-20-2013, 10:46 AM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
I have an been trying to figure out what's on the other side of the housing. I now know that the one with the yellow top and two prong terminal is a seperate temperature sending unit, but I can't figure out what it sends a signal to. The other has a VDO stamp on it, but I don't know what it is and I can no longer read the numbers on it to reference. Any one have any ideas ? I would upload pics, but I can't for some reason....
The temp. sender would be #15 in hornhospitals link, the other switch/sender/sensor is #16.
Any help would be appreciated
Old 04-25-2013, 09:23 PM
woodenbmw's Avatar
Re: Identify this for me
Finally got them to go through
What are they and what do they do ?
ID:	373115   Click image for larger version
Old 04-25-2013, 10:02 PM
D'oh, You Kids!
The 35*C 8 second sensor is the cold start injector timer/sensor. If the coolant temperature is lower than 35* C, it fires the cold start injector for 8 seconds when the key is turned from off to run/start. There are different temperature and time sensors available. They are explained in the Bentley Manual. If you don't have that manual, you need one. The other two I already explained..... one tells the ECU what the coolant temperature is, and the other operates the instrument cluster gauge.
Quotes to live by:
Old 04-25-2013, 10:19 PM
woodenbmw's Avatar
Thanks for the info, and you're right, I do need to get a bentley manual. Would it also explain to me what the yellow top temp. sender goes to ? I've been running a bit warmer than normal, but I'm not sure. The gauge will go up to about halfway, I'll tap the cluster a few times and it goes back down. I'm thinking a bad connection somewhere, but new switches and sensors can't hurt
Old 04-25-2013, 10:55 PM
D'oh, You Kids!
Here:
Name:	coolant temp sensor.jpg
Quotes to live by:
Old 04-27-2013, 12:20 PM
woodenbmw's Avatar
Thanks again. I will get that manual asap
