Engine ticking sound - Bimmerfest - BMW Forums
Old 04-25-2013, 10:37 AM
cinergi cinergi is offline
Mein Auto: 2006 525i
Hello All,
I'm experiencing what I believe is a variation of the N52 engine valve lifter ticking issue. My symptoms are as follows:
- At startup (cold engine), no ticking.
- When idling (warm engine after driving), slight ticking.
- Above idle, no ticking.
The ticking is never severe. Are these symptoms cause for concern or normal? The car runs fine.
cinergi
Old 04-25-2013, 11:40 AM
Bad Debt's Avatar
Bad Debt Bad Debt is offline
Mein Auto: 2005 BMW 545i
usually a VANOS or lifters issue. Search it.
'05 545i, Auto, Orient Blue, Beige Dakota,Bamboo Anthracite, Logic 7, Xenon, PDC, Premium Package, Mtec V2 AE, 19" E92 M3 Rep. Wheels, M5TEC Bumper , MTEC rear bumper, 70k miles as of 1/13.
Old 04-25-2013, 12:11 PM
Thanks Bad Debt, I've read about the lifter issue, BMW's TSB on this topic, and its resolution involving the replacement of valvetrain parts and in some cases the entire head, with varying degrees of success. However, my symptoms seem slightly different in that there's NO ticking at cold startup, and slight ticking only at idle when warm (disappears above idle). Also, in the threads I've read there seems to be no consensus on whether this issue is harmful to the engine (BMW claims it's not, some others claim it is). I'm wondering if it is in fact harmful, because otherwise I can live with the slight noise since my car is out of warranty and replacing valvetrain parts or the entire head are very costly and in my view drastic measures.
Thanks!
cinergi
Old 04-26-2013, 07:31 PM
racooper3 racooper3 is offline
BMW Master Wannabe
Thanks!
cinergi
How about worn timing chain guides?
Old 04-27-2013, 12:06 PM
H F H F is offline
Mein Auto: 2005 545i
cinergi,,,,Try getting a piece of wood 1/2 inch by 1/2 18 inches long (I kno,,, sounds primitive ) put one end on any engine part while running and the other end on your ear. Wood has a great transfer of sound, ull b amazed at how good all the engines sounds travel through the stick. It will pin point the location of the ticking sound.
Even a long screw driver will work but I think the wood stick pics up sounds better...Put the end of the stick on your injectors, valve covers, timing covers ect.. Im Positive you will locate the sound this way. its worked great for me in the past. Its a cheap, primitive but very effective tool
Old 04-27-2013, 05:53 PM
Thanks everyone. The sound definitely comes from the valve train. Since it's so minor and only happens at idle with the engine warm, and since I can't really do anything about it without spending lots of money for BMW's updated engine head design, I'll live with it. I can't even hear it unless I'm outside the car standing right in front of the engine in a quiet location.
cinergi
Old 09-06-2015, 12:12 PM
Tom Tom Tom Tom is offline
Mein Auto: 530i and 535d e60
My 530i e60 does it as well do not open your engine do not experiment anything once the engine warms up fully it goes way it won't harm your engine or the performance
I think another common fault from ikea products (Bmw)
Old 09-06-2015, 01:49 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
What does Ikea products have to do with BMW?
Old 09-06-2015, 02:16 PM
I was being sarcastic
Because BMW cars are becoming very fragile
Not the reliability they used to have
