Old 10-07-2012, 03:49 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Brake Pad and Rotor - OEM Brand
Hi Guys,
I want to get rid of the break dust (if possible). Are there any rotors and pad that will not have break dust and yet efficient.
Also, what OEM brand of brake rotors (preferably those ventilated ones as they look cool), brake pads and brake fluid have you guys used on your E60 that you will always stick by?
My breaks would be coming up soon, and so I am starting to prepare for this DIY.
P.S.How expensive is to change the part which holds the brake pads and are coloured.
Thanks.
Old 10-08-2012, 09:48 PM
CleanE60's Avatar
CleanE60 CleanE60 is offline
Mein Auto: 2010 535i xdrive
Yeah a dinan upgrade, but this is far more than just cool looking...
stick with oem and use wheel wax this will help you easily wipe away your dust at every stoplight as we all have too... I prolly wipe my wheels down 4 to 5 times a week. Thats part of this German thing.
Keep it clean!
Old 10-09-2012, 09:25 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
The akebono's are good and low dust as well as the Hawk pad. Take a look at our site and see what we have. Here is a link to our pads there is another area on our main page where you can check out our Hawk pads.
http://www.eaceuroparts.com/parts/pa...e/31/2010/4857
Old 10-09-2012, 10:33 AM
CleanE60's Avatar
Besides being bias towards your product are they really as good as OEM pads?
Keep it clean!
Old 10-09-2012, 11:01 AM
Past Sponsor
Mein Auto: Many
The akebono's are an extremely good pad . The Hawk pads are something that we install and we use as well in our vehicles. The customers that we have installed them for seem to like them however some people don't like them as well as the akebono's or other pads of their preference. Of course we would like to have your buisness but I don't want you to buy anything that you wouldn't be happy with. I have not really received any commplaints on the akebono's so that is what I would recommend first. Take a look around and atleast compare our prices.
Old 10-09-2012, 03:58 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Akebono are ceramic pads. They create less dust and it is more white or neutral, so less visible. However they are not as grabby as oems, so everyone need to decide what is more important to them. Highy efficient pads tend to be dirtier, so it's a trade off.
I tried ceramics and they came off after a week. I hated them. Brakes feel greasy and slippery and you have to press the pedal much harder to get a response. I almost rear ended a truck on the highway with them, that's when i phoned in an order for oems!
I heard good things about Hawk HPS and will give them a try at some point. (Either Textar or Jurid make BMW pads, so look for those as well.)
I have both a 535 sedan and wagon. The sedan has much better brakes and I discovered it is because the rotors are about an inch larger! Now I am researching how to get larger rotors on the wagon, at least in front where it matters. That should make a huge difference.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: Cobb Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 10-09-2012, 04:00 PM
Oceans10's Avatar
How can I fit a 348mm rotor on an E61? Are there calipers available to fit?
Old 10-09-2012, 05:06 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
If the caliper on E61 is the same as E60 then I think you are good to go; but I wonder if the E61 is XI thus have CV joint which makes the whole suspension to be different compare to non-XI (your sedan for example).
I agree with you ceramic in general is less grabby.
BTW when discussing pads please states the type not just brand. Hawk makes ceramic but the one that midle-road is HPS (from what I heard from people), less dust; some says as much as 50% less dust than OEM and about the same or 20% more braking to boot. Yes Akebono ceramic that I have on my X5 virtually dust free but a bit spongy and you need more effort pushing the pedal.
All due respect to John@EAS, I bought depo for my X5 from EAS.... but TireRack website most helpful determining which pads may suit your need, they have indicator on:
dust, noise and performance; dust always mutual exclusive vs performance.
Old 10-09-2012, 05:13 PM
Oceans10's Avatar
All E61s are Xdrive.
I wonder if anyone have come up with a better brake solution for that car.
There is a world of difference between my 535i Sport RWD and the E61 wagon. Night and day. It's like an F1 vs a tractor in terms of braking quality.
Old 10-10-2012, 07:01 AM
IMHO, BMW is lagging behind when it comes to AWD compare to Audi. Audi put real performance suspension, sits lower etc on their AWD cars. Wish I went ahead with 335is instead of 335-coupe xi, the is has bigger brake on already. No more AWD BMW for me unless it's an X6 50i
Old 10-18-2012, 07:24 PM
kskane's Avatar
From DownUnder
Has anyone used Ferodo brake pad on there E60 and know if it is good?
Old 10-22-2012, 02:19 AM
jackMA jackMA is offline
Mein Auto: '06 525Xi
I have not used the Ferodo pads. Chances are, if the pads are a ceramic material, there will be less dust on your rims.
I replaced the fronts and rear pads with Hawk HPS pads recently. What use to be a weekly cleaning of the rims with original pads is now a once a month cleaning with the HPS pads. I like the HPS pads braking performance, a slight increase over the OEM pads, but I find that I have to apply more pedal pressure to hold the car when its stopped. For me, that's a reasonable trade off.
Before replacing the pads, check your rotor thickness with a micrometer. You'll need a 1"-2" range for the fronts. I think the minimum thickness is 28.4 mm (1.118") but you should check that. The OEM rims wear quickly. Mine were toast at about 70k miles.
Old 10-22-2012, 03:11 PM
hooch999 hooch999 is offline
Mein Auto: 550i
E61 would actually brake better because of AWD - when slowing engine brakes all wheels at the same time unlike RWD helping to shorten braking distance.
If you have issues with braking check your disks, brake pads, brake master cylinder, replace brake fluid.
Old 10-22-2012, 03:15 PM
Oceans10's Avatar
If you have issue swith braking check your disks, brake pads, replace brake fluid, brake master cylinder.
Uhm, my cars use brake pads on rotors. The engine is not involved in the braking process.
Old 10-22-2012, 04:08 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
Not sure what year BMW started using engine braking, but I know my sport auto transmission will downshift and employ engine braking when I'm going downhill and depress the brake pedal. But as far as I can tell, that's the only time it uses engine braking.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 10-26-2012, 12:05 AM
kskane's Avatar
From DownUnder
That is adaptive transmission doing that gear change, nothing to do with engine.
Sent from my Android Bug
Old 11-13-2012, 09:22 PM
CarGuyHere CarGuyHere is offline
Mein Auto: 535Xi before a 330Xi
I have the Hawk on my Corvette, and really like them. Low dust, never squeal, and great brake feel.
Old 04-05-2013, 06:46 PM
kskane's Avatar
From DownUnder
Guys thanks for your contributions, so I have the following different ones listed;
Textar
Jurid
Hawk HPS
Akebono
Any more suggestions for pads and what about the rotors? Any brands for rotors?
Old 04-05-2013, 07:44 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
rotors = Centric, R1 Concepts, Zimmerman
The pads listed are all good, check here for a review: http://www.turnermotorsport.com/t-bu...rake-pads.aspx
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-27-2013, 07:31 AM
kskane's Avatar
From DownUnder
E60 owners, this is a call for brake pads and rotors as everyone's contridbution is important. Following is the list I have so far and I can feel the brake pads are going to go anyday now as the car does not likes to stop or maybe it is my racing driving pattern, who knows. If you have had better experience than any listed below, then I would like to hear your voice.
Brake pads:
Textar
Jurid
Hawk HPS
Akebono
Rotors:
Centric
R1 Concepts
Zimmerman
Question I have about rotors, I have done enough research on rotors and found that the slotted or drilled or combo are mainly for racing and does not have much affect on street usage, they are mostly for the looks. Would you agree with it?
Old 04-27-2013, 08:15 AM
Oceans10's Avatar
I use Hawk HPS with Centric Cryo treated rotors. Quite pleased with them.
Slotted and crossdrilled actually reduce the amount of surface the pads are in contact with. Also wears down pads faster. It's intended for cooling, but for normal driving it is not necessary. The size of the rotors and the air that flows between the twin discs provide lots of heat dissipation. (Track duty is completely different. You are constantly stressing the rotors and heating them up. You'd never drive like that on normal roads, so there is plenty of time for the rotors to cool off.)
Textar and Jurid are oem pads, this is what BMW uses, just with their own name stamped on them. They work great, just throw off a lot of black dust. Hawks work just as well but are more durable and a lot less dirty.
I have heard good things about Akebono, but just happen to hate ceramic pads. They feel slippery to me and have no feel.
Old 04-27-2013, 01:48 PM
H F H F is offline
Mein Auto: 2005 545i
Has anyone tried Brembo rotors or brake pads ?
Old 04-27-2013, 02:06 PM
H F H F is offline
Hey bro,,, what kind of wax and where u get it at.. Every time i tried waxing or polishing my wheels it seems like the dust got worse and got dirtier faster.. So now i dont use anything on them now.. just wash'em every friday
Old 04-27-2013, 09:24 PM
GoRavens's Avatar
GoRavens GoRavens is offline
Mein Auto: 2007 550i
They are mainly for looks, but they look great!! I love my slotted and drilled ones from ACUTE. Prem R1 w/ Hawk HPS. I will do it again..... no regrets.
2007 550i Black Sapphire on Black (Sport, Prem., Nav., Cold Pkg., Logic7, Comf. Seats & Access)
-Hard-Wired Escort 9500ix, Black Carbon Fiber Roundels (body & wheels), Black Kidneys, 35% Tint (sides & rear), Cont. Extreme Contact DWS, R1 Prem. Rotors w/ Hawk HPS pads from ACUTE, OEM MTech Front/Rear/Sides
Old 04-28-2013, 01:08 AM
kskane's Avatar
From DownUnder
Boys, I know this is repost, but has anyone used Ferodo brake pad on there E60 and know if it is good?
