Old 04-27-2013, 10:48 PM
balbs balbs is offline
Mein Auto: 2006 BMW 525i
E60 Sunroof Seal Replacement DIY
I noticed some water stains on my headliner and also, there is some very significant audible difference between when the sunroof shade is closed or open. I figured that it's time to replace the sunroof seal.
What you need:
New seal: Part No. 54107245551
Goo Gone for cleaning off the adhesive. http://www.autozone.com/autozone/acc...er=539309_0_0_
A couple of rags for wiping and cleaning
Scissors or cutters to trim the seal
Black silicone adhesive sealant. You can get this from Autozone. It comes in a tube. http://www.autozone.com/autozone/acc...er=526731_0_0_
Initial Warning. Work by standing in the back seat area. If you work in the front seats, you may be tempted to put your foot down on the passenger seat and possibly mess up your OC3 or passenger occupancy matt. If you do you can get the dreaded Passenger restraint malfunction errors on the iDrive.
First off, using a masking tape, I marked the center of the sunroof towards the rear window. This gave a center and beginning point of installing the new seal.
Then I began to start peeling off the old sunroof seal. Taking off the old adhesive is lengthy. It's best to just sort of roll it off...
Some of the old adhesive rolls I took off:
Once you got all the adhesive off, use some Goo Gone to clean out all the extra adhesive. Then use a wet cloth to wipe up all the Goo Gone until the surface is nice clean.
Once all the adhesive is cleaned up, I noticed that there is a small dimple to mark the center. It seems I didn't need to use the masking tape to mark the center after all.:
Now it's time to install the new seal. Notice the big difference in size\width between the old and new seal. I think the new seal is redesigned to be thicker.:
As you can see, there is a lip that extends out. That goes on the top side of the sunroof.
From there, peeling and mounting the new seal is self explanatory. Start mounting and feeding the new seal and work your way around the sunroof. No need to worry about stretching the seal to make sure you have enough, because you have plenty. When you finally reach the end, cut about 1.5mm extra and make the ends meet.
A little extra I did was to fill in the gap with some black silicone adhesive.
Once you're all done, it's time to initialize the sunroof. Otherwise, the sunroof anti-trap may not let you close the sunroof.
I took the car for a test drive and what a difference it made in road noise as far as the sunroof is concerned. I can't tell an audible difference whether or not the sunroof shade is closed or not. I still have to do a freeway test though.
Old 07-06-2016, 12:09 AM
ghs235 ghs235 is offline
Desi
Mein Auto: 07 550i SMG, 09 MB ML550
I'm so glad I found this 3-year old thread last week. I had no idea that the road noise from open sunroof shade is not normal. Followed the well written instructions here and replaced the sunroof seal. After 2 hours of labor and 2 blisters on both my thumbs, I am extremely happy with the result. No more discernible increase in road noise when I open the sunroof shade. Even on the freeway.
10/10, would recommend all E60 owners to do this.
Old 07-06-2016, 01:03 AM
Glad it helped you out. I still have my E60 and the sunroof is still leak free. Also, yeah, I remember my thumbs' nail bed was sore afterwards.
Old 08-30-2016, 10:08 AM
eoxaal eoxaal is offline
Mein Auto: E61, F11
I searched online on this topic, and found some mention of the need to recode the system for the new seal. "PUMA measure AG20315810-01"
Do you think this is really needed?
Old 08-30-2016, 11:08 AM
eburnz's Avatar
eburnz eburnz is offline
:D
Mein Auto: Dirty 530i
has anyone ever experience when its raining, and the roof is tilted open, u hear a weird noise, hard to explain so ill try my best... it sounds like a soft knock I forget what culture it is but it sounds like an African language but its not English...
2004 BMW 530i (Prod: 7/2004)
Sports package | Prem package | Prem sound package | Cold weather package | Light package | 18x8 Matte Black / 20mm spacers: 15mm offset | Carbon Fiber: Grill, Side mirrors, M5 trunk spoiler, LED gear shift knob, Interior trim | Mtech v3 AE | M5 front bumper | Interior white LEDs | Smoked side markers | Muffler delete | Dual exhaust gun metal tips
RIP Selina - 2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Old 08-30-2016, 11:15 AM
No need to code. Just follow the sunroof initialization procedure as shown in the video.
Old 08-30-2016, 11:18 AM
It's probably the metal deflector. When the sunroof is open or tilted, you can feel for the plate. It's spring loaded so you can push it down and it goes back up. However, when it's up, it tends to hit the top of the roof when you drive over slight bumps or uneven roads. What I did was I used a piece of wood to keep it from going down but push down on its edge so that it bends a little lower until it stops hitting the top of the roof.
Old 08-31-2016, 05:34 AM
DanielFD's Avatar
DanielFD DanielFD is offline
Mein Auto: 2007 BMW 550i
about the need to code you sunroof. its not coding but programming (also called updating). It updates the antitrap tolerances to accept the new seal. Most people skip that step and are fine, i wouldn't worry about it.
2007 Silver Grey BMW 550i - Black Dakota Leather - Premium Package - Sport Package - Premium Sound Package - Cold Weather Package - Navigation - PDC - Eibach Pro-Kit on M-Sport Shocks - Kumho Ecsta LE Sport Tires - High Gloss Black Grill, Trim, and Exhaust Tips - Euro Taillights - Debadge - 5000K Angel Eyes, Interior, and BMW License Plate LED Bulbs - Silver Amber Turn Signal Bulbs - Osram Night Breaker D1S Bulbs - MULF2 and 6FL Retrofit
Old 02-20-2017, 02:21 PM
okii okii is offline
Mein Auto: 530i
E60 sunroof seal
Hello-
I had water accumulating under the rear bench seat. No water in trunk or in the front or rear foot areas. Purchased a new sunroof seal and replaced per the DIY instructions. Followed the sunroof initialization procedures after installing the seal. Had a pretty heavy rainfall that same night and found no water in the car!!!!
Thanks!!!
