Transmission mounting problem - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 02-19-2013, 06:34 PM
Bimmer980 Bimmer980 is offline
ljk
Mein Auto: e46 330
Hi all,
I recently replaced the guibo and center support bearing on my girlfriend's e30 ('89 convertible, 5 speed). After putting it back together, the transmission sits high on one side, and it makes a scraping sound when it's in any of the 2nd and 4th gear (the rear gears).
I had a jack under the transmission for part of the job to stabilize it. I also raised the engine several inches (by the oil pan) to lift the engine, so I could put the motor mount back on the passenger side (had to remove temporarily it to get some working room to get the exhaust off).
See pic below.
What is making the transmission sit high, and what can I do to fix it?
Old 02-19-2013, 09:27 PM
hornhospital's Avatar
D'oh, You Kids!
Looks like you ripped one of the tranny mounts. The one on the left in the picture looks like it's separated.
Quotes to live by:
BMW-CCA #441426
Old 02-20-2013, 04:35 PM
ljk
Mein Auto: e46 330
The transmission is supposed to rest on that mount. For some reason it is sitting elevated above it. Any ideas?
Old 02-20-2013, 05:17 PM
D'oh, You Kids!
Because it's separated. It's junk. Replace it.
Quotes to live by:
BMW-CCA #441426
Old 02-20-2013, 06:59 PM
downhiller's Avatar
livin large
go solid mounts
Old 02-20-2013, 07:21 PM
ljk
Mein Auto: e46 330
Anyone got a parts car, or work-in-progress, they can loosen one mount on? I'd like to confirm for sure that 'a new mount' is going to fix the problem. I have a feeling it won't. Thanks.
Old 02-20-2013, 08:27 PM
ljk
Mein Auto: e46 330
Originally Posted by downhiller View Post
go solid mounts
Where would I get those?
Old 02-20-2013, 08:35 PM
D'oh, You Kids!
http://www.pelicanparts.com/cgi-bin/...%2FiC%20%20%20
Quotes to live by:
BMW-CCA #441426
Old 02-20-2013, 08:45 PM
ljk
Mein Auto: e46 330
Found the rubber mounts, thanks. I was asking about the solid ones.
Old 02-20-2013, 08:55 PM
D'oh, You Kids!
I wouldn't recommend solids for a daily driver. Too much NVH.
Quotes to live by:
BMW-CCA #441426
Old 02-21-2013, 06:12 PM
downhiller's Avatar
livin large
all the places ive seen them dont have them anymore or the website doesnt work. but ive only searched the 2 i can remember
Old 02-21-2013, 08:07 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
+1
OP, check the right front engine mount (diagonally opposite) hasnt collapsed.
E30 above Sold
Last updated 2nd January 2014
Old 02-26-2013, 07:01 PM
ljk
Mein Auto: e46 330
Found the noise coming from gears 2 and 4. There's a circular piece of metal (stabilizing part?) that goes around the driveshaft, it's part of it, you can see it (the circular part in the upper right corner) in the picture. It rubs against the 'arm' that runs between the bottom of the shifter and the transmission.
I think the driveshaft is holding the transmission higher than it normally should be?
Is there a specific way to lower the driveshaft. I don't want to drop the exhaust again...
Old 02-27-2013, 07:24 PM
downhiller's Avatar
livin large
it does automatically shorten unless you bent/was given the wrong CSB when doing the first project. i would really turn your focus at the engine and tranny mounts before you start messing with the driveshaft again
Old 02-28-2013, 05:55 AM
BMWFatherFigure's Avatar
Old School
Get brave and admit it went wrong in the re assembly stage. take it to bits and put it back together properly - maybe using a manual this time. No easy way out of this.
Current:
E38 Parts Car
Previous:
Old 02-28-2013, 04:02 PM
ljk
Mein Auto: e46 330
Originally Posted by _Ethrty-Andy_ View Post
+1
Thanks Andy, I missed your post above. I actually removed that mount to get some space when getting the exhaust loose. Sounds like I could have changed the engine positioning or a number of things. If I'm understanding you correctly, I'd want to raise that side of the engine, correct?
That makes a lot of sense...Andy's post clarified things. I think the CSB was the right one, but if worse comes to worse, I'll be seeing it again :/
It could have (possibly) gone wrong, but the rest of your post is reaching, quite a bit. We'll save our 'other' opinions for later. Thanks.
Old 04-28-2013, 10:13 PM
ljk
Mein Auto: e46 330
fixed it
For those wondering,
The transmission mounting bracket is asymmetrical, and I had it turned around backwards ... I figured this out after taking a careful, careful second look.
Old 04-29-2013, 03:00 AM
dont know how i missed that, i was even looking at the picture for a second time now before reading your post above thinking gosh that right side mount looks squished like the marshmellow part of a s'more lol
E30 above Sold
