The X5 SAV Forum
Old 04-28-2013, 11:11 PM
mrjayviper mrjayviper is offline
Mein Auto: n/a
jacking the car up to the stands
I've been reading various guides and some of them talk about putting up the car up jack stands.
like I'm flushing the radiator or doing a change oil, do I need to put the car on jack stand on all 4 corners? What situation requires jacking up the car on all 1 or 2 or 4 corners?
thanks
Old 04-29-2013, 01:13 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The car should be level when draining fluids. A set of ramps should be had for times when not doing wheel/suspension work.
Front wheels on the ramp, jack the rear and set on stands.
Sometimes when doing a coolant flush, the vehicle doesn't even have to leave the ground. (On X5's)
The radiator drain is right there in front (after removing splash shield of course) and the engine drain isn't too far in and some people can reach without jacking it up. Can't be a big guy/gal, but if you're small enough it's doable. (On X5's)
Old 04-30-2013, 01:22 AM
flyace20 flyace20 is offline
Yippikayaaaay
Mein Auto: 2002 X5 4.4
You only need to jack it off....oops I mean jack it up if you need to get underneath the car. I can fit under and reach the oil drain plug so I don't have to put it up on jacks.
'02 BMW X5 LOVE THAT CAR
