E36 (1991 - 1999)
Old 01-13-2013, 09:04 AM
dc_wright's Avatar
bimmerfest Supporting Member
Great! Thanks for posting the fix! Most of the time we just assume the fix happened because the poster goes silent. If you have a few minutes and can snap and post a photo of the area you're referencing that will make it easier for the next person to figure this out.
elliottw elliottw is offline
Mein Auto: nada
I'm new to BMW but not new to forums. Not posting once you fix is poor form indeed.
Old 03-29-2013, 02:13 AM
Ryanwileyusa Ryanwileyusa is offline
Mein Auto: 1999 323i vert
99 323i vert wont open, red flashing light
fully auto. top wont go down when i push button, red light just keeps flasshin and i hear the motor, any ideas?
Old 03-29-2013, 02:15 AM
Old 03-29-2013, 09:26 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You're so close! Read the documents in the first post. My bet is a microswitch, or maybe the motors.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 03-29-2013, 12:03 PM
i reset the motors and nothing
Old 03-29-2013, 02:12 PM
dc_wright's Avatar
When the red led is flashing it means the top controller is sensing a fault. It could be that one of the motors has lost sync and the controller doesn't know its position or it could be a microswitch in the wrong condition.
When you "reset the motors" do you mean you disengaged them and manually moved the top to the fully down position and performed the resync procedure?
Old 03-30-2013, 08:59 PM
No I didn't manually put top down . I took back seat out pulled lever put it back in position and went to trunk and locked both Motors in place . With fully auto top I didn't think I had to put top down??? So I should put top down?? And do it again?
Old 03-31-2013, 03:56 AM
dc_wright's Avatar
The top must be in the fully down position to run the re-initialization procedure. There are some instructions floating around that tell you to do it in the fully up position, but that's not correct. Go to the first page of this thread and to the very first post. Download the third file there titled E36 Convertible Adjust and follow the instructions on pages 18 and 19 to perform the re-initialization.
Old 03-31-2013, 02:17 PM
Mine is fully auto so it doesn't pop open like these directions say
Old 03-31-2013, 02:51 PM
petriej's Avatar
Please make your own thread for more help on this. We don't want to make the sticky any messier.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-14-2013, 07:13 PM
dc_wright's Avatar
What to replace if you're having an interference issue with the storage compartment lid and the top.
File Type: pdf Vert_Top_Compartment_Lid_Interferences.pdf (114.8 KB, 447 views)
Old 04-15-2013, 09:53 PM
Bimmerlemar Bimmerlemar is offline
Mein Auto: 97 BMW 328i
Has anyone had the problem with the top not fitting properly into the bed and it knocks the lid out of alignment? Tips on fixing this?!
Old 04-16-2013, 03:00 AM
dc_wright's Avatar
What do you mean but not fitting properly? Do you mean it hasn't folded all the way into the compartment before the storage compartment lid starts to close? If that's the case you need to resync the top. Instructions for doing that are in the trouble shooting PDF at the first post of this sticky.
Old 04-24-2013, 02:25 PM
toonky toonky is offline
Mein Auto: Bmw e36 320i cab
Hi!
I have problems with my soft top on bmw...
I had it in a garage all winter and i took off the battery so it wouldn't run out of power..
And now when spring is coming and i took out the car from the garage the soft top won't work?
I thought i had to reset the soft top because of the battery..
But when i try to reset the soft top, NOTHING happens?! None of the motors are running it's like i'm out of power...
I have checked all the fuses including the the one by the battery in the trunk.
It's all dead, i don't know what to do...
Please help!
Tony
Old 04-24-2013, 02:30 PM
petriej's Avatar
My guess is the microswitch for the trunk is malfunctioning.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-25-2013, 11:17 AM
Truth is my cables in my trunk burned...So the cables from the microswitch are off. So i can open my trunk without the microswitch connected. The soft top has still worked anyway even when the cables were gone. And when i press the microswitch i can still hear it click...
The only thing i did was taking off the - pole from the battery...
If it helps maybe...My right window is f*ed up, i have done a reset on all widows though.
Old 04-27-2013, 02:55 PM
mrsean mrsean is offline
Mein Auto: Bmw 328i convertible 1996
Okay I have a !996 328i Semi auto top I'm so lost! I'm car illiterate! I had the back window part go up. Besides that I us it as a manual top! Please help me If anyone is in Maryland Please email me seanshepherd1992@live.com Maybe we can meet up and you can help me I'd pay you what I can! PLEASE HELP!
Old 04-28-2013, 08:24 AM
chipper1000 chipper1000 is offline
Mein Auto: 1994 325I convertible
Smile Top down
My top is now working thanks to this post. I will be back often!
Old 04-28-2013, 01:40 PM
dc_wright's Avatar
If the rear portion of the top lifts, but the opening stops at that point you've probably got a problem with the S4 microswitch. If you had a problem with the top motor or the controller I don't think you'd get the rear portion lift. S4 is located on the top frame on the driver side at the hinge point just above the point where the front and rear windows meet. Once the rear portion of the top has lifted, you have to lift the front high enough for S4 to switch and that tells the top controller to finish lowering the top. If S4 doesn't switch when you push the front of the top up, the controller thinks you haven't moved it and will sit there waiting forever.....
Old 04-29-2013, 01:01 PM
Hi!
Please help!
Anyone? It's completely dead, what should i start with? the led on the switch isn't even blinking...It's completely dead.
/ Tony
Old 04-29-2013, 01:36 PM
petriej's Avatar
Start with the trunk microswitch.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-20-2013, 10:29 AM
Hi
My soft top doesn't work...it happens nothing when i try to do the reset procedure...Anyone?
Please help!
/ Tony
Old 06-01-2013, 10:05 AM
brinkadore brinkadore is offline
Mein Auto: BMW 328 IC
more info please
is it a full auto top? there is a difference in micro switches and in the operation between auto and semi-auto. Mine is full auto, and the only time the switch light didn't work, the controller behind left rear panel was unplugged.
this link has good info for troubleshooting:
http://forums.bimmerforums.com/forum....php?t=1585851
If more sane people were armed, the crazies would get off fewer shots!!!
Old 06-01-2013, 11:41 AM
dc_wright's Avatar
The only difference is the full auto top has two additional micro switches in the front bow area that help control the operation of the mechanized latching system in the front. All the other micro switches are in the same location and serve the same purpose. The only difference in operation is the release and lift of the front portion of the top past the tension point is done with motors on the full auto where , on the semi auto the front bow is release and lifted past the tension point by the driver.
automatic top, knucklehead, stuck closed
