Old 04-29-2013, 03:30 PM
kwikk4 kwikk4 is offline
Mein Auto: 95 740i
engine shut down
hello. was on my way home and at a red light and my engine just shut down. make a vibration(rutter) and shut down. any ideas? just replaced the ccv valve last week and had just started running better after adding lubro moly valve clean and injection cleaner. I HAVE A NEW BATTERY ALSO. CAR WON'T TURNOVER. I HAVE POWER. THE MILEAGE(DAILY) WENT BACK TO ZERO.THANK U IN ADVANCE FOR YOUR REPLIES.
Old 04-29-2013, 05:08 PM
Mein Auto: 95 740i
hello. did some research. I"M ABOUT 99 PERCENT SURE ITS MY CRANKSHAFT POSITION SENSOR. WILL HAVE IT TESTED TOMORROW. HOPE THIS HELPS OTHERS. WILL LET U KNOW.
Old 04-30-2013, 01:18 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
If its your crank position sensor the car will turn over but not start. I hate to say this but the way you discribe a vib/rattle when it stopped, I would say look at your timing chain. Take off your oil cap and look down in there with a good light and see if you see anything. Grab the chain too and see if its loose.
Old 05-01-2013, 06:37 PM
Bigrobsbmw Bigrobsbmw is offline
Mein Auto: 2004 745i, 2001 740i
Can you hear the starter engaging but it will not turn over the engine ? Sometimes the extra chain or broken guides will lodge in the lower timing cover and bind things up. This could be good, since it was at idle at a stoplight you may not have bent the valves.
Old 05-01-2013, 07:53 PM
Mein Auto: 95 740i
Locked up
I had a guy look at it. The flywheel he couldn't get to move. It locked up. He thinks the bearings on the bottom locked it up.i'm going to replace the engine. Almost 179000 miles. 500 for the engine and 5-6 hundred to put it in. I can"t beat that. New gasket, seals, etc. U could barely see a little glistening in the oil. Timing chain was not loose. Any other ideas let me know. Thanks. Mike
Old 05-02-2013, 12:10 AM
If you can get an engine for $500 Id say go for it.
