Lower coolant hose that connects to water pump...whats the part number? - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 04-29-2013, 10:29 AM
Mrathell Mrathell is offline
Mein Auto: 2000 X5
Hello everyone, I'm iin the middle of changing the water pump on a 2002 X5 4.4 that I purchase for $1500 the other day.
I have the water pump off, so now I'm ordering the parts that i need to replace.
The smaller lower hose that goes from the water pump and connects to a black platic box on the lower passenger side of the radiator needs to be changed but i don't know what part number or the name of this hose.
I tried doing a seach on Ebay but it's hard to tell from the pictures.
Does anyone on here know?
Thank you in advanced.
Old 04-29-2013, 10:58 AM
ChezWhiz ChezWhiz is offline
Send a message via AIM to ChezWhiz Send a message via MSN to ChezWhiz Send a message via Yahoo to ChezWhiz
Mein Auto: 2001 X5 4.4i
http://www.realoem.com/bmw/select.do?vin=XXXXXXX
Replace 'XXXXXXX' with the last 7 digits of your VIN.
Colby,
[Dead] 2001 X5 4.4i w/ 139K miles (probable cracked engine block)
2005 X5 4.4i w/ 97K miles
Old 04-29-2013, 01:00 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Looks like its part number 11537500750. Use this diagram. Note that it connects to the bottom of the radiator. It also has the coolant temp sensor at the bottom which has an oring that should be replaced because leaks always happens right there. Thank bluebee for the ring size and check it out here.
Now you do say its connected to a box on the lower passenger side which sounds like it would be your transmission thermostat.
In that case it's number 3 in the diagram above, but that doesn't come from the water pump. Number 1 in the diagram is four hoses connected and on of them also goes to that "box". Also that hose assembly can only be ordered that way.
Old 05-01-2013, 02:04 PM
ECSTuning's Avatar
Instructor of the Stig™
^ agreed sounds like 11537500750, I have it available HERE. Below is a photo of this part for reference.
Also HERE is a link to my cooling section for the M62 X5, I think you'll find the part selection and photos very helpful.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
