E30 (1982 - 1993)
Old 04-17-2013, 09:30 PM
actletpone actletpone is offline
Mein Auto: E30 320i
running rich
My car seems to be running rich at idle to the point that anyone who stands near it comments on the smell.
I'm not sure why it is running rich. I have tested the coolant temp sensor, throttle position sensor, cleaned + tested the idle control valve, replaced the air filter and swapped in another air flow meter.
The only other things I can think of that could cause this are the ecu, fuel pressure regulator or injectors. The car has no 02 sensor from factory.
I know I have a vacuum leak on the intake boot and intake manifold gasket, so it should be running lean if anything.
Could it just be the fact my car came factory with no catalytic converter?
Old 04-17-2013, 10:27 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
Fpr.
Old 04-18-2013, 09:54 AM
downhiller's Avatar
livin large
negative on the intake leaks and running lean. at idle is the highest amount of vacuum closing the fpr. as the throttle opens, the vacuum goes down opening the fpr. i would start there
Old 04-18-2013, 12:51 PM
Mein Auto: E30 320i
Cheers, logic told me it would make it run lean but I was guessing and did wonder if it somehow caused the opposite effect. What your saying makes sense. In a couple of months I plan to give the car a bit of an overhaul cam belt/sub frame bushings/ fix the vacuum leaks etc. So I will see what the result is.
Old 04-18-2013, 02:27 PM
Prost's Avatar
Prost Prost is offline
Mein Auto: 06 650i, 08 MINI ClubmanS
Originally Posted by First time View Post
Fpr.
Call me stupid, what is fpr?
1992 325i Convertible M-Technic II Appearance Package
2002 530i Sport Pkg (Since 7/2015)
2005 X3 3.0i (Lease return in 2008)
2006 330i (Lease return 2009)
2008 Cooper S Clubman (Sold)
2006 650i (sold)
2011 535i M-Sport (ED September 17th, 2011,redeliver on 11/15/2011, sold)
2011 Z4 SDrive35is (ED September 17th, 2011, redeliver on 11/9/2011, Lease return on September 2013)
2013 M3 (ED pickup April 23rd, 2013, redeliver on 6/28/2013)
BMWCCA: 359118
Old 04-18-2013, 03:38 PM
hornhospital's Avatar
D'oh, You Kids!
OK, you're stupid. Kidding!
FPR= Fuel Pressure Regulator
Quotes to live by:
BMW-CCA #441426
Old 04-18-2013, 05:32 PM
Prost's Avatar
2006 650i (sold)
BMWCCA: 359118
Old 05-02-2013, 01:19 PM
Mein Auto: E30 320i
Is it possible to remove the intake manifold without removing the thermostat housing and / or injectors?
Old 05-02-2013, 06:27 PM
downhiller's Avatar
livin large
injectors come off with it as i recall. thermostat housing stays
Old 05-12-2013, 02:46 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
@ actletpone. Did you ever figure out what caused your problem?
Big Boyz with Bad Toyz.
Old 05-13-2013, 03:31 AM
Mein Auto: E30 320i
Been real busy lately but have new intake manifold gaskets I hope to install in a few days. So I will see how it goes.
Old 05-19-2013, 08:31 PM
Mein Auto: E30 320i
This is the condition the cylinder 1 intake gasket was in. It was sitting like that in the inlet port.
Car seems to be running better and I think the smell has gone. Thanks.
Old 05-20-2013, 05:10 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
At least now you know that somebody with clumsy fingers had worked on your engine before
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
