The X5 SAV Forum
Old 05-02-2013, 05:55 PM
X5 E53 Driver X5 E53 Driver is offline
Mein Auto: BMW X5 E53 4.8is & 3.0i
Brake System Job
Hi , I just replaced my brakes pads and my Rotors on my 02 X5 , so my question is do I need to Bled or Breath or whatever you called The Break System because its may gotten air in to the brake system after I did all that job ??? So if someone know about it can help me out thank you.
Old 05-02-2013, 06:42 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
There should be absolutely no need to bleed the brakes if you didn't crack any lines. If you took the brake lines off, the yes. If you (for some reason) messed with the lines up by the brake booster under the hood, then yes. If you turned the bleed screws on the calipers, then yes.
If all you did was use a C-clamp to squeeze the pistons back to clear the new (thicker) pads to fit, then you shouldn't need to bleed.
When the vehicle is restarted the brakes may go to the floor initially, idling will get the pressure back from the boost pump. Also be sure to "bed" the new pads to the rotors by driving from about 60 MPH, then firmly but steadily (without activating ABS) slow down to about 40 MPH without coming to a complete stop (probably highway).
Do that a few times (6-7) then drive around a bit to cool them off, and all should be well.
Good Luck.
Old 05-02-2013, 07:15 PM
Brake System Job
Thanks man that was really helpful information , yeah I didn't did something wrong no broken liens no thing I used the C clamps to get the bistons back and I did everything's as it should I just want to make sure , and Tomorrow I will burn my Bimmer in the Highway to 160MPH haha Lol no I am not gonna do that hahaha but 145 MPH is possible to me hahaha.
