dj auto city lights? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-29-2013, 11:13 PM
frac_E36 frac_E36 is offline
Mein Auto: 93 325is
bought some dj auto, headlights used. previous owner had city light socket installed and wire ready to be spliced.
i spliced it to the corner light on the passenger side. tried to turn it on, nothing happened. i oped up the back of the light, saw it had a ground wire. i plugged in the connector for the high beams, with the corner light wire still hooked up, when i turned on the corners the highbeams came on.
frustrated and i want to know what happened, if you know anything let me know. thanks
Old 04-30-2013, 01:19 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
It's grounding through the high beams. Connect the ground from the city lights to an actual grounding point (the brown wire from the corner light) and it'll work without the high beams coming on.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 05-02-2013, 10:48 PM
Mein Auto: 93 325is
found out what it was, i had the wires going into the connectors wrong.
heres what it finally looks like.
