Old 04-27-2013, 01:11 AM
erdengurcan erdengurcan is offline
Mein Auto: 5 series
F10 Cornering Fog lights
Hello everyone, Cornering Fog lights working for F30's without the adaptive lights.
Look at the video;
How to do that for F10's?
Old 04-27-2013, 01:27 AM
demge01 demge01 is offline
Mein Auto: F30 320ed
Look at the video;
Yes this is a useful feature. I have it coded on my F30 with non adaptive Xenons.
Coding for F10 should be similar? Details are on the F30 cheat sheet.
Old 04-27-2013, 01:45 AM
Mein Auto: 5 series
I couldnt find on the F30 cheat sheet, Could you share the code with us?
Old 04-27-2013, 02:44 AM
Sure yes here it is:
3073 LaMaster1, FC - C_CLC_ENA - F30 DISABLE > F30 ENABLE
3073 LaMaster1, FC - C_BLC_ENA - F30 DISABLE > F30 ENABLE
3066 LceTmsCoding1, FC - KL_ENABLE_LI - KL_AUS > KL_EIN
3066 LceTmsCoding1, FC - KL_ENABLE_RE - KL_AUS > KL_EIN
3062 LceLampMapping1, A5 - MAPPING_ABBIEGEL_L_OUTPUT - OFF > NSW_L
3062 LceLampMapping1, A5 - MAPPING_ABBIEGEL_R_OUTPUT - OFF > NSW_R
All in the FEM module. All six need to be done. You get cornering in auto lights mode only and also they light up together when reversing.
Old 04-27-2013, 10:17 AM
Mein Auto: 5 series
There is no FEM Module on f10s, only FRM. But there is no similar things as f30
Old 05-03-2013, 02:23 AM
Mein Auto: 5 series
I found some codes for F10, but nothing effect for now. Still working on it, may somebody help?
ALC_AFS_ENABLE - Cornering lights installed
AHL_ENABLE - adaptive headlight
ABBIEGELICHT_MIN_AUSG_AKTIV - Enabled Minimum PWM for cornering at
Ansteueruerung on switch-on.
MIN_END_GESCHW_KRV_AUS > Abbiegelicht durch NSW
MAX_END_GESCHW_KRV_AUS > Abbiegelicht durch NSW
KEIN_ABBL_BEIM_BLINKEN_RKW - when the reverse gear is not turning light blinks
ABBL_BEIM_TIPPBLINKEN - Enable cornering lights and turn signal through
AUSG_11_NSW_L_IS_INDICATOR
AUSG_12_NSW_R_IS_INDICATOR
Old 07-11-2013, 09:24 PM
https://www.bim https://www.bim is offline
Mein Auto: 528i
hi,
may i know have anyone find out how to program the foglight as the turning light yet?
Old 07-11-2013, 09:49 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by https://www.bim View Post
hi,
The cornering lights on the F10 are the inside headlights, and on the F30 they are the Fog lights. I don't think you can make the Fog lights turning lights on an F10.
You can look in FRM though, for C_CLC_ENA or something similar.
Old 07-12-2013, 03:07 PM
Osoliman Osoliman is offline
Mein Auto: F30 328i
Hello I have an F30 with no auto headlight, meaning no,light sensor and headlights do not turn on by themselves and there is no auto position in headlight switch.
I tried the below to get cornering fog lights and it did not work. Any idea if there is a workaround or it is a must to have auto light switch
Old 07-12-2013, 04:26 PM
I have no idea. I can't believe BMW sells a car without an Auto Headlight switch either.
Old 07-12-2013, 05:11 PM
Mein Auto: F30 328i
Manufactured in Egypt plant. I can take a pic of my headlight switch if you like
Old 07-12-2013, 05:22 PM
No, I believed you, i am just in disbelief BMW actually does that.
Old 07-12-2013, 05:36 PM
Mein Auto: F30 328i
Yeah it is a shame , it should be a standard feature but what can one do
