E30 (1982 - 1993)
Old 04-30-2013, 04:59 PM
irishmyst49 irishmyst49 is offline
Mein Auto: 325I
E30 A/C and blower not working
My 1989 325 convertible had the compressor replaced last year. Recently the AC stopped blowing cold air and now the blower wont work for heat or cool. Any ideas.
Old 04-30-2013, 07:35 PM
downhiller's Avatar
livin large
fan control switch
Old 04-30-2013, 08:09 PM
Mein Auto: 325I
I replaced the fuse and got the blower working but still no cold air. Is there a separate fuse for the A/C?
Old 04-30-2013, 08:23 PM
kingdd kingdd is offline
Banned
Mein Auto: red
Can find relevant information on the Internet
Old 05-01-2013, 09:04 AM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is online now
Mein Auto: 1989/1991 E30; 2000 E38
Hopefully you system has been converted to R134. That would increase the amount of troubleshooting you can do before you require an AC tech. Check the following things. Start the car, turn on the AC with the fan speed set to 4, and set the temp dial to the coolest setting. Look through the kidney grills and ensure that the AC fan it working. Connect an AC pressure gauge to low pressure connection. AC pressure should be above 30 psi for the compressor to turn on. Make sure the AC compressor clutch is engaged and the front portion of the pulley is spinning. Now look at the AC receiver dryer. It's located behind the passenger headlights. Look at the inspection window on the receiver dryer for the flowing refrigerant. Excess bubbles usually means you have a low charge. If the charge is low, add 1or2 cans of freon. If the still does work, take it to a tech. You could have a bad pressure sensor, clogged lines or valve.
Big Boyz with Bad Toyz.
Old 05-03-2013, 08:31 AM
Mein Auto: 325I
Thanks for the reply, I will try that.
