The X5 SAV Forum
Old 05-02-2013, 05:41 PM
rwink181 rwink181 is offline
Mein Auto: X5
About to replace my AMP
Hello all I'm new to Bimmer so be nice. I blew my Amp and I was about to buy one from a used Vehicle, my question is will the new one be plug and play or will I have to get it coded?
if so whats the best and less expensive way to do it. Thanks for the help.
Old 05-02-2013, 06:46 PM
Mein Auto: X5
Oh yeah it's a 2003 X5 E53 3.0
Old 05-03-2013, 07:04 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Both...it will be plug-n-play...but will need to be coded if it came from an e38 or e39 etc. The e38/e39/e53 all use the same amp (or DSP amp if so optioned)...but they are coded based on which vehicle and sound system is installed in the car. The coding takes into consideration the location of the speakers in the vehicle, how many speakers, and the interior dynamics of the vehicle etc.
Again, the amp will work (if it is the correct amp (DSP or non DSP)...but the sound may be muddled & unclear if it came from a vehicle that is not like yours, or is like your but not optioned the same as yours. That's why you'll read that a replacement amp needs to be coded. But again, if you are getting it from an e53 that is optioned the same way yours is...then you won't see any of the issues aforementioned.
Q {BMW CCA Member #191509}
(SOLD)
Old 05-03-2013, 07:26 PM
Mein Auto: X5
Thanks for the knowledge, the new one has the same info on the label as mine so I might get lucky. Thanks again.
