E46 (1999 - 2006)
Old 05-01-2013, 09:36 PM
supercruiser supercruiser is offline
Mein Auto: BMW 325i
Question Broken Oil Tank Bolt
Hi everyone,
I changed oil on my 325i, and I broke the bolt when I tightened it. The threaded part of the bolt is now inside the oil tank. How bad is it? Do I need to take it to the dealer to have the bolt removed?
Thank you.
Old 05-01-2013, 10:20 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Do you see the hollow shaft to the bolt (assuming OE bolt)? If so get an Easy Out of the appropriate size. There should be little to no tension now that the head is broken.
Old 05-02-2013, 05:26 AM
ahull's Avatar
ahull ahull is offline
Originally Posted by supercruiser View Post
Hi everyone,
Thank you.
The bolts are made to break when overtightened so you don't ruin the pan. If you don't have a torque wrench, you should finger tight down onto the *new* crush washer and then go 1/8 to 1/6 of a turn more - no more.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-02-2013, 07:47 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
I wonder if you could fish it out thru the disptick tube hole using a magnetic wand... having just had mine apart to replace my CVV, the hole is large enough that I think it would work if you could get a long enough magnetic wand in there.
You'd need to remove the intake parts to the throttle body to get access, but it's not too difficult. A new seal for the dipstick tube will be needed also.
Jeff R.
Old 05-02-2013, 09:11 AM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
Isn't it easier to just remove oilpan and take piece out and then put oilpan back?
Old 05-02-2013, 09:30 AM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
No.
Removing the oil pan to change the gasket rates anywhere from a difficulty of 7/10 to 9/10 from many DIY's I have seen online.
Old 05-02-2013, 09:51 AM
ahull's Avatar
Originally Posted by OfTheLost View Post
No.
Agree. Dipstick hole is a good suggestion - at first I was thinking jvr meant dipstick tube which is too small, but the hole in the "top" of the pan after removing the dipstick tube should be large enough as stated.
If that doesn't work, my other thought was put in a magnet or a magnetic plug so that the bit will eventually find it and stick and then take it out whenever the pan has to be removed for a new oil pan gasket. It's not like the chunk could get sucked up in the pump due to the screen on the uptake.
Old 05-04-2013, 07:58 AM
Mein Auto: BMW 325i
Thank you, all, very much for your replies. I'll work on the car this weekend and try your suggestions.
Old 05-07-2013, 07:29 PM
Lbert Lbert is offline
Mein Auto: 325i
I suspect the oil pan bolt stem is likely still attached to the oil pan housing so fishing it out is not an option. I doubt the bolt stem is floating inside the pan.
As someone already mentioned with the head part of the bolt detached there is not much tension left on the bolt stem.
Your best option is to get this tool: http://www.harborfreight.com/12-piec...set-40349.html
Use a punch before drilling so the drill bit does not dance. After you drill the hole, engage the extractor and turn to the left.
Old 05-19-2013, 12:23 PM
Mein Auto: BMW 325i
Wink
Finally had time to attend to the problem. It wasn't that bad at all. The bolt (plug) was still in the housing, as few of you have mentioned. The bolt is hollow inside, as cvx5832 mentioned, and that made it very easy to drive it out. All I needed was a $2.99 Easy-Out tool (see attached pix). Since the bolt had hollow shaft, I slid the EO tool in and tapped it very lightly, then I used an adjustable wrench and started turning the EO tool CCW. From there on, it took me almost no effort to loosen and remove the bolt. I also purchased a new drain plug with hollow shaft and a crush washer to replace the broken one. My Bimmer is up and running .
Thank you all for your help!!!
Old 05-19-2013, 06:47 PM
Mein Auto: '04 330Ci 6-speed
Nice happy ending.
Now consider gettng a vacuum pump to change the oil thru the dipstick housing.
Old 05-19-2013, 09:59 PM
Mein Auto: BMW 325i
Haha... Actually haven't thought of a vacuum pump, but I did get myself a nice torque wrench.
