E46 (1999 - 2006)
Old 05-04-2013, 05:21 AM
wil137 wil137 is offline
Mein Auto: 2003 BMW 330i
Misfire During warm up
Hey Guys, I got a alraming diagnosis in my DME that say Misfire, in cylinder 1 and 6 during warm up and misfiring at operating temperature. Misfire in 5, 3 and 2 during warm up. The actually error below:
EE/B6 - Misfire, cylinder 1, misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F3/B6 - Misfire, cylinder 6, misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F2/B2 - Misfire, cylinder 5, misfiring during warm up, worsening emissions (Misfire CARB_B1)
F0/B2 - Misfire, cylinder 3, misfiring during warm up, worsening emissions (Misfire CARB_B1)
EF/B2 - Misfire, cylinder 2, misfiring during warm up, worsening emissions (Misfire CARB_B1)
What you think is causing this?
Old 05-04-2013, 06:26 AM
ahull's Avatar
ahull ahull is offline
Couple of thoughts. Has it sat for a while and this is first start in over a week? If so, could just be spark plugs slightly fouled and needing to clean themselves by running for a while- reset the codes and see if they come back on next start up after a good drive. If no other codes, how old are your plugs years/miles? Are they the right plugs for the car? Your CCV could be passing too much oil vapor through the intake and your plugs are fouling due to the excess oil. Pull one of your plugs and compare it to a plug reading guide you can find by googling. You can tell how well your car is running by how your plugs look.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-04-2013, 07:57 AM
Those plugs are new and are the right ones for sure. Maybe it is my CCV. How do I check that.
Old 05-04-2013, 09:32 AM
ahull's Avatar
They are not bosch plugs are they? Bosch have been known to perform poorly in our cars, as odd as it sounds. NGK platinums w/ 4 electrodes are recommended. NGK Iridium tip will work too.
Most replace the CCV preventively around 80-100k miles. If you do a lot of short trips or went for a while with a failing thermostat that ran the engine too cool, you'll get a faster buildup of residue/sludge in there. It tends to be worse in colder climates too. To check it, the test is to start the car, take off the oil fill cap and place a ziploc bag over it. If it gets sucked in slightly, you're fine. Sucked in strongly or blown out strongly and the CCV usually has a problem.
At 85k, mine had the slightest buildup on it. I probably could have gone another 60k with no problem, but I'm in a warmer climate and have a healthy commute to work every day that gets it up to temp for at least 20 minutes each way.
You can also pull a plug or too after a run and see if you have wet oil on it.
No oil in the plug wells when you changed them? The valve cover gasket around them can leak oil into the wells and cause problems.
Otherwise make sure all the coils are on the plugs good and connecters on tight.
Old 05-04-2013, 09:48 AM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
Miss fires have 4 popular causes.
1 engine mechanical issue, like low compression causes incomplete burn in the engine. The mixture ignites in the exhaust.
2. Fuel issue I.e cars running too rich. A likely cause is a vaccum leak in the intake tract after the mass airflow sensor. The dme uses the mass reading to determine how much fuel to squirt. If less air gets to the engine tthan it thinks it runs rich.check the idle air valve one of those hoses might be cracked.
3. Ignition issue delayed or week ▀park will cause this, old plugs etc weak coils.
4. Restrictions old dirty airfilter or more likelyBlocked or failed cats. Replace those.
Old 05-04-2013, 11:06 AM
Sadly I did installed bosh spark plugs and I did change the value gasket. I thought that bosh part where the best parts to use in BMW. I will try out your trick with the ziplock and see what happens.
Old 05-04-2013, 12:03 PM
I tried the CCV test, only with my hand and i felt the suction. It dont feel too hard. Also I clean my MAF. After a drive later I will check it and see if the code are still there.
Old 05-04-2013, 12:30 PM
ahull's Avatar
From the wiki:
"It is strongly recommended to ONLY use the OEM specified NGK plugs for replacements. Bosch Platinum 4 plugs are also available for the M54 engine but will often not perform, cause misfires and set CEL light and codes. Better stick with the NGKs even though they are more expensive. "
Cleaning the MAF is never a bad thing. Sounds like your ccv is fine. Hoses on it do get brittle or oil soaked over time so it's a good PM item at around the age of your car.
If you seated the plug well parts of the VCG properly then I doubt that would be the problem, but not a bad idea to check. The notch around the bolt hole on the farthest and closest ends of the plug well gasket pieces only seats one way and will leak if put on wrong. Ask me how I know But I had put on a Victor Reinz brand VC gasket that was crap and leaked everywhere anyway so I had to redo it.
I'd think if some of the other issues posted were your issue you'd have other codes besides misfires. I'm strongly leaning towards get some NGK plugs and try them out.
Old 05-04-2013, 02:34 PM
direly noted. It suck that bosh plugs could be the source of my problem. I thought that BMW were shipped with bosh plugs. Now I am hoping I bought the right brand fuel filter, which is MAHLE. What you think about that?.....I almost bought a bosh filter thinking that bosh is the best.
Old 05-04-2013, 03:02 PM
ahull's Avatar
Bosch is usually high quality. For everything else (electronics wise) I'd say it's gold, but just a weird problem with the plugs... EDIT: It's probably one of those situations where they wanted to get into the spark plug business and contracted it out and they didn't get it right for this application.
Mahle.... I see a mahle/kayser on a reputable vendor's site. I think mine was the same. Should be fine.
Old 05-04-2013, 03:14 PM
ahull's Avatar
PS Read the wiki. Link is above your first post on this page. Tons of good stuff in there.
